SageTV United Kingdom SageTV and SageTV Recorder Users from the UK - This forum is for you to post about specific issues using SageTV software in the UK. |
SageTv Sky Digibox and USB to RF2 Device
Hi all
I've been using beyond TV up till now and using this device to change channels on my sky digibox through Beyond TV http://www.heenan.me.uk/control-sky-from-pc/ I'm using the Trial version of Sage TV at the moment but if i can get this device to work then ill be buying the full version. I've read this thread concerning the device. http://forums.freytechnologies.com/f...ad.php?t=19809 Sage TV recognizes the EXETuner plugin and I can select it when I'm setting up my video source but when I change the channel in Sage nothing happens Here is the reg file I'm using as per the instructions to test it [HKEY_LOCAL_MACHINE\SOFTWARE\Sage\EXETunerPlugin] "command"="echo %CHANNEL% >> c:\channel.txt" ========================================== Does anyone have this device working with Sage ? If so can you tell me what you did to get it working ? Thanks |
I have that device and it works really well. I posted my registry key in this thread :
http://forums.freytechnologies.com/f...661#post236661 I seem to recall having problems when Sage was running service mode (although it runs fine now) try turning that off and see if that helps, if it does I'll try to remember how I resolved it :-D Tim
Tecra M5, 2 x HD200, 2 x HD300 2 x PCTV 290e Win 7, Sage 7.1.9, Phoenix 2 STV Stephane's XMLTV Importer, Digiguide, |
Controlling Sky or Sky+ Digibox from SageTV - without IR ! | r4qm4n | Hardware Support | 4 | 07-14-2010 12:42 AM |
SkyEye Controller for Sky Digibox | Mahoney | SageTV United Kingdom | 6 | 01-25-2006 10:11 AM |
