Old 05-23-2008, 09:45 AM
Zervun Zervun is offline
Howto: Install Java correctly for sage
After stumbling around this in the past, and getting a few PM's on it I thought I would make a readme.
This information extended from bastafidli's thread (much credit to him) http://forums.sagetv.com/forums/showthread.php?t=29968 and the link in that thread http://www.howtoforge.com/installati...5.1-desktop-p7
Linux is kind of an eye sore with java. Many distros don't come with an up to date java, due to Sun licensing. One of these is debian, Centos is the same way. Centos provides rpm's but I've never found them to be good with java
Some Comments -
from bastafidli:
Maybe the first step should be to uninstall gjc or to do not install gjc in the first place when installing Linux. I have never found any real use for it and since we are going to install full Java anyway, it is not needed.
from stuckless:
Under ubuntu # sudo apt-get installl sun-java6-jre
from Chip33az:
I know in Etch, one can install sun-java5-jre (I had main contrib and non-free enabled).
I have added the backports.org repository and they have sun-java6-jre (I think it is 1.6.06).
FYI on backports under debian (not tested by myself but Chip33az has)
# vi /etc/apt/sources.list.
add - deb http://www.backports.org/debian etch-backports main contrib non-free
# apt-get update
-- Note: All backports are disable by default - if you want to install something from backports
apt-get -t etch-backports install “package”
or under aptitude
aptitude -t etch-backports install “package”
first off - this is on a default debian install - etch
#java-version
java version "1.4.2"
gij (GNU libgcj) version 4.1.2 20061115 (prerelease) (Debian 4.1.1-20)
1.4.2 is way old - we are going to grab a newer one
Download Java JRE for linux from http://java.sun.com - you do NOT want the rpm, and you want 32 bit if there is an option
I'm going to grab 1.5.0 update 15 - it downloads as jre-1_5_0_15-linux-i586.bin
#chmod +x jre-1_5_0_15-linux-i586.bin
#./jre-1_5_0_15-linux-i586.bin
hit spacebar a few times it will ask you to say yes, and then will extract to a directory - lets then move it to /opt because we installed sage there probably
#mv jre1.5.0_15/ /opt
-------Read this for going full system install of java between the marks if not skip beyond (have only succesfully done this on Centos not Debian base)--------
This is Centos steps and I have not successfully figured this out as there is no /etc/profile.d in debian that I can find just /etc/profile in debian etc, so if you are successful in debian do share
You will notice, that well this didn't override system settings for java - java-version still shows the old one - you don't really need your system completely updated, but if you do hit up http://www.howtoforge.com/installati...5.1-desktop-p7 on 7.1.3 Sun Java JRE about half way down the page. You are going to have to edit profile.d/java.sh, as well as alternatives install.
Here is a brief synopsis
link it to mozilla
#ln -s /opt/jre1.5.0_15/plugin/i386/ns7/libjavaplugin_oji.so /usr/lib/mozilla/plugins/
#vi /etc/profile.d/java.sh
add or adjust (it's a blank file most of the time)
export J2RE_HOME=/opt/jre1.5.0_15
export PATH=$J2RE_HOME/bin:$PATH
#source /etc/profile.d/java.sh
#alternatives --install /usr/bin/java java /opt/jre1.5.0_15/bin/java 2
#/usr/sbin/alternatives --config java
Select the new JRE
Check to make sure it is ok
#/usr/sbin/alternatives --display java
and
#java-version
you should now see your new version
--------------END FULL SYSTEM JAVA INSTALL-----------------------
Ok - so if you did the above full system install, you can probably just run java as normal - if not follow these steps, as default java will still be pointing at 1.4.2
#vi /opt/sagetv/server/kegen.sh
under #!/bin/bash
PATH=/opt/jre1.5.0_15/bin:$PATH
export PATH
#vi /opt/sagetv/server/startsage.sh
export PATH
This will have sage use the jre1.5.0, if you want to try different versions just adjust.
I found that if I didn't do it to the keygen it would report encryption errors on registering your key
Old 05-23-2008, 10:45 AM
bastafidli bastafidli is offline
Old 05-23-2008, 11:14 AM
Personally, if your distro has a java package for a recent jre, then I'd use that package first. It'll be easier to maintain the long run.
Ubuntu 8.04 (and even earlier releases) had fairly recent java packages.
Old 05-23-2008, 11:16 AM
Ya, ubuntu is an exception, debian doesn't have it, and Centos/Redhat/Suse seen to have rpm's after the fact
This way allows to test multiple java instances though which is nice
Old 05-23-2008, 11:19 AM
The full install would definately be ideal, I just can't figure out the java.sh and profile.d locations in debian.
I'm actually a Centos man, my next task is to 64 bit it, and get Kmod with XFS.
I tried debian for just cross knowledge and also XFS out of the box. Ubuntu is a bit to cutting edge for my linux tastes but seems like easier out of the box.
My intention is to get some install instructions on each OS in 64 bit in the future you inspired me bastafidli
I run a commercial Centos 5.0 server, so thats the one I really want =)
Old 05-23-2008, 11:28 AM
chip33az chip33az is offline
I thought Debian did have it.
Of course, my machine isn't working right now, so I don't know if the backports java works right
Old 05-23-2008, 11:33 AM
Going to keep adding your guys's comments on the first post - it's nice getting all this info
Sage6 install craters windows firewall gateslinger SageTV Software 1 12-26-2006 05:39 PM
Java question matrix35 General Discussion 0 12-04-2006 04:12 PM
Java problem with AwtToolkit Ctrl-Z SageTV Beta Test Software 0 11-01-2005 09:32 AM
Java Runtime - Fresh Install Error greggerm SageTV Software 10 03-04-2004 07:17 AM
java install error 1722 batorok SageTV Beta Test Software 2 02-26-2004 10:20 AM
