Empty Recording Schedule
First time I've seen this happen. Something in the scheduling subsystem is acting strange. Yesterday morning, the wife noticed livetv wasn't working (would stop after about 5 mins of watching). At first glance, I noticed the diskspace bar was showing 0 upcoming recordings. The recording schedult was completely empty. checking the favorites, they are all still there, and the guide is properly populated. None of the future airings were showing anything as flagged to record. I figured it was a corrupted wiz.bin, so I backed it up, and deleted it, and reimported my fav's from and XML saved form the web server. The schedule populated immediately. next morning, same things happened, empty schedule, stopping livetv. Anyone seen this before? i tried clearing out all plugins on the server, and no change. This was a fresh wiz.bin as of yesterday morning, so i can't imagine it's some sort of corruption. Next thing to try is wiping the sage.properties - but not sure anything in there that would cause this.
Sounds more like a capture device issue... Have you rebooted the server?
SageTCPServer (2.3.5): Open source TCP interface to the SageTV API MLSageTV (3.1.8)/Sage Media Server (1.13): SageTV plugin for MainLobby/CQC TaSageTV (2.58)/TaSTVRemote (1.14): Monitor/control SageTV with an Android device TbSageTV (1.02)/STVRemote (1.11): Monitor/control SageTV with a PlayBook 2 TiSageTV (1.64)/TiSTVRemote (1.09): Monitor/control SageTV with an iPhone/iPod/iPad |
oh yeah, been rebooted, and the devices are all still 'functioning'.
SageTV server & client: Win 10 Pro x64, Intel DH67CF, Core i5 2405s, 8 GB ram, Intel HD 3000, 40GB SSD system, 4TB storage, 2x HD PVR component + optical audio, USB-UIRT 2 zones + remote hack, Logitech Harmony One, HDMI output to Sony receiver with native Intel bitstreaming |
Is the correct date and time on the server itself?
Yep, correct time and date - and time zone. I ended up removing all the lineups and re-adding them (only have one added right now), and it seems to be populating the recording schedule properly now. Will have to watch it to make sure it sticks.
This happened to me once. I could not seem to clear it up without restoring the entire SageTV program files folder from a recent backup. It only happened to me the one time, though.
HP m9040n Quad Core 2.4Ghz, Windows7 Ultimate, Ceton 4 tuner CableCard with SageDCT, 2 HDHomeRun QAM, Netgear 24 Port GiGE Switch, Linksys WRT600N Router, 3 HD200 Extenders, 2 SageTV Clients Server: SageTV 7 |
Yeah, in 6+ years working on the same wiz.bin, this is the first time it's happened to me... most likely a corrupted file (but NOT the wiz.bin it seems, as wiping it didn't fix the problem). Had to repair the sagetv installation.
Fuzzy,
This just happened to me again...and restore does not seem to be fixing it. I tried a Repair re-install of 7.1.9 and it did not fix it. Is that what you mean when you say you "had to repair the sagetv installation"?
Yeah, used repair from the setup file. The only thing I can think of is it may have corrupted the wiz.bin, so you may have to roll back to a previous one as well.
I think the Wiz.bin does get corrupted, but something else in the sageTV environment is corrupting it, which would explain why replacing only the wiz.bin does not fix it - it gets corrupted again...maybe something out of whack in the sage.properties?? Next time I will replace the wiz.bin and sage.properties files from backup and report back. Thank goodness for a good backup strategy!
I know this is an old thread, but just in case someone has figured it out....this keeps happening to me, about once a week for the last few. Only restoring the ENTIRE SageTV folder from a recent backup fixes it. Anyone have this, and figure it out?
I don't know if this is the problem you had/have or not. I had this problem because ALL my tuner sources were copies, none were direct from the data source. I made one download, and all the others copies, and that fix it.
Server #1= AMD A10-5800, 8G RAM, F2A85-M PRO, 12TB, HDHomerun Prime, HDHR, Colossus (Playback - HD-200) Server #2= AMD X2 3800+, 2G RAM, M2NPV-VM, 2TB, 3x HDHR OTA (Playback - HD-200) |
I just had a partial No Data show for my program guide. It seems that my digit HD channels are fine. But any of my non-HD channels are showing no data now. My HD channels are with the antenna and the non-HD are clear qam channels. They were fine earlier this week and now they are not. I did not change any setup. What can I do?
Intel Core Duo 2.5mhz, 2gb RAM Windows Home Server, Sage 7 beta 2 Hauppauge PVR-250, 1 PVR-500 MCE 1 HDHomeRun 4TB Storage, GB Network 2 MVPs, 1 HD100 & 1 HD300 |
UPDATE: Reference to said problem http://forums.sagetv.com/forums/show...8&postcount=41
Athlon II Quad Core 3Ghz, 8GB Ram. 12GB Storage. 3 (x4) HDHR for OTA Across 2 Cities, HD200, 2x HD300. Last edited by BobbyDing; 04-02-2012 at 09:54 PM. Reason: adding link to said issue. |
![]() Did you ever conclude what you thought the problem was, and, when you say you used "repair" from the "setup" file, what exactly do you mean - never done that before. thanks
Sage 9 server = Gigabyte AMD quad-core - 4 gigs - integrated ATI HD4200 chipset - SSD boot, Hitachi Deskstar show drives. HD-PVR - Colossus - Win7 32 bit. HD200/300’s networked. HDHomerun tuner. "If you've given up on Weird Al, you've given up on life" - Homer Simpson |
Recording Schedule - Beta 6.5.8 | jm987 | SageTV Beta Test Software | 16 | 02-10-2009 08:25 PM |
Copy recording schedule to another PC? | wirecreative | SageTV Software | 7 | 09-24-2007 02:36 AM |
Recording schedule filling itself | jonnyfrag | SageTV Software | 3 | 03-10-2006 08:38 AM |
SageTV Recording schedule help. | Fluffdaddy | SageTV Software | 3 | 12-28-2003 12:52 PM |
Recording schedule not filling | Worf | SageTV Software | 8 | 12-11-2003 12:12 PM |
