Old 02-03-2017, 07:58 PM
opendct location
Okay sorry to be a bother people but I'm trying to learn unraid. I installed the sagetv docker with no problems, I even installed OpenDCT docker and its working but what if I want to edit some of the docker settings. Where would I find them I used midnight commander but I can't find where the OpenDCT flies are located.
Old 02-04-2017, 10:12 AM
both of those dockers set up their configuration areas to a shared folder.
//TOWER/appdata/sagetv/server
and
//TOWER/appdata/opendct/etc/conf
where "TOWER" is the name of your unRAID server. You should be able to navigate to these from a windows pc on your network and edit the files there (I like notepad++ on windows to edit these - and just about any other - files).
Old 02-04-2017, 08:37 PM
Thanks Fuzzy the problem was it did not install the docker correctly there wer no files under appdata. I thought it should of been there but it wasn't. So I just wiped the unraid install and re did everything from scratch. Everything seems to be working now. Everything seems to be working better now with the clean install. Especially now that I have a better idea of what I'm doing.
OpenDCT and R5000 checkbin Hardware Support 9 12-29-2016 12:54 PM
OpenDCT vs SageDCT for upgrade to v9 from v7 crarbo1 Hardware Support 9 12-28-2016 04:43 PM
Broke my OpenDCT? ThePaladinTech Hardware Support 2 03-29-2016 03:19 PM
OpenDCT: Can I use it? SDeGonge Hardware Support 7 02-20-2016 10:27 AM
InfiniTV4 with OpenDCT tomdomm Hardware Support 58 02-03-2016 07:00 PM
