Old 03-04-2011, 11:38 PM
darcilicious's Avatar
Where have all the movies gone?
Eeek! Just upgraded to 7.1.2.249, server running on Vista x86 SP2 and PC client running on Windows 7 x64 (no SP1 as of yet). After copying the entire SageTV folder for the server to another drive, I installed the beta on top of the existing installation.
Everything is looking GREAT (including the new version of Diamond, wowza!) but NOTHING shows up in the TV>>Recordings>>Recorded Movies screen and no movies show up in the All Recordings screen. AND same for the Archived Recordings. Absolutely. No. Recorded. Movies. Anywhere. I say again: eek!
All my (current) recordings are in a single folder on the WHS (and the archived recordings in another folder on the WHS) and all those movie FILES are there, they just no longer show up in SageTV.
I've been using BMT and fanart and as of a couple of days ago (when I last perused SageTV) all the recorded movies were there just fine.
Also, movie files in the Videos/Folders sections are just fine
So, I still have the wiz.bin from right before I upgraded -- would that help do some kind of database restore within this version? Or should just bag this and downgrade to 7.0?
Thanks for any hints or ideas to try!
Old 03-05-2011, 12:02 AM
As a quick test, I recorded the last few minutes of a Muppet movie and even that doesn't show up in the Recorded Movies screen after the recording completed...
I'm currently recording another movie from MGMHD (The Premature Burial) and it's not showing up either...
Old 03-05-2011, 12:38 AM
jorton jorton is offline
If you are using Diamond v3 it filters recorded movies out if recordings and into the movie view(s) by default. Have you looked in the movie views?
Look in the filters for TV and also the filters for each movie view.
Movies don't really work well with banner views. You could create a custom movie view based on one of the wall/flow/listflow views and filter to only show recorded movies.
Jeremy
Old 03-05-2011, 01:42 AM
evilpenguin's Avatar
Yeah, that's defaulting to not include movies (which is my bad because I wrote it ). Should probably be the other way around so people don't get scared, i'll change it for the next version.
Clients: 1xHD200 Connected to 50" TH-50PZ750U Plasma
Server : Shuttle SFF SSH55J2 w/ Win7 Home, SageTV v7, Core i3 540, 2GB RAM, 30GB SSD for OS, 1.5TB+2x1TB WDGP for Recordings, BluRay, 2xHDHR, 1xFirewire
SageTV : PlayOn, SJQ, MediaShrink, Comskip, Jetty, Web Client, BMT
Having a problem? Don't forget to include a log! (Instructions for: PlayOn For SageTV v1.5, MediaShrink)
Old 03-05-2011, 05:48 AM
What and where are "movies views"? Do you mean "Videos"?
The filters selected (in the TV section) are Movie and Film and yet neither show up. Which filter should I be using to make my recorded movies show back up under, well, recorded movies? Seriously dudes
Ah, now I understand the "Evil" part of "EvilPenquin"
Thanks folks!
(Also, when I select a different theme from Diamond, I still have no recorded movies which seems really bad/wrong/scary but disabling Diamond all together seems to do the trick)
Old 03-05-2011, 06:50 AM
jusjoken jusjoken is offline
I summed up the responses in the new Diamond FAQ...
Where are my Recorded Movies
Old 03-05-2011, 06:59 AM
PLUCKYHD PLUCKYHD is offline
Thanks folks!
The better question is why do you want movies in tv section we did fudge by not resetting that filter when you go to recorded movies. I let my recorded movies flow into my date added custom view of movies.
Also changing diamond themes does nothing but change the look to get rid of diamond functions you have to disable diamond
Old 03-05-2011, 07:08 AM
I want recorded material to show up where it says "recorded" I mean "television shows" are "videos" too (in fact, my ripped TV shows show up videos so why not just move "recorded tv" there too? )
The Diamond views under "videos" are nice but just aren't where I go for my recorded material I have the HAF to consider too
Anyways, looks like the next release will fix this for me...
Old 03-05-2011, 07:17 AM
You can fix it now but just changing the filter...
And tv videos dont show up in videos in diamond if your metadata is right
Old 03-05-2011, 07:27 AM
Originally Posted by PLUCKYHD View Post
You can fix it now but just changing the filter...)
Ah, thanks, a second look and I found it
Old 03-05-2011, 10:21 AM
In the FAQ for this, it says:
"Use Movies/Video views"
The wording here might better if it matched the wording in Sage so:
"Use Videos and then one of the 'Diamond' views such as Wall, Flow, List Flow, or Categories."
Cheers!
Old 03-05-2011, 10:40 AM
Cheers!
Updated the FAQ... thanks for the feedback.
k
What movies are on right now? rykr SageTV Software 3 09-04-2009 08:23 AM
Movies in SageTV hehe299792458 SageMC Custom Interface 2 03-07-2009 09:03 AM
All MOVIES Page possible? Eckwell SageTV Customizations 1 03-04-2009 03:03 PM
can I group all recorded movies into a MOVIES group Deacon Crusher SageMC Custom Interface 5 06-05-2008 12:22 PM
Help! Where are my movies???? Boxpin SageTV Software 3 02-28-2005 08:09 PM
