Old 04-06-2020, 12:55 PM
tvmaster2's Avatar
HD300 'Hostname' in System Info
I got a used HD300 from another member here a while back, and am getting around to implementing it, except something is odd:
In the Setup Menu/System Information/System Status area, the HOSTNAME is listed as 'Tango3', which is I assume the last owners Server hostname?
Any idea how I get that to correctly read the hostname of MY server?
I've done a RESET of the HD300 I believe, so that wasn't it.
I also looked in the properties of my SageTV Clients folder, found the MAC address for this unit, but could find no line item for 'HOSTNAME' in the properties file.
Any ideas?
Old 04-06-2020, 01:48 PM
graywolf's Avatar
graywolf graywolf is offline
The hostname of the HD300 is tango3
tango3[~]# cat /etc/hosts
127.0.0.1 localhost
127.0.0.1 tango3
Old 04-06-2020, 01:51 PM
tvmaster2's Avatar
127.0.0.1 localhost
127.0.0.1 tango3
every HD300 in the world's hostname is tango3?
sorry, not following.
EDIT - just checked all my HD200's, whose hostname's are all STP-HD200. Naturaly I thought the HD300 followed suit. Apparently not, as I checked my older HD300... tango3.
What's up with that? Could be the stupidest thing to call the machine? There must be a reason...
Old 04-06-2020, 03:04 PM
wnjj wnjj is offline
The hostname is only on your local network. I assume the 3 is because it's version 3. Tango3? I don't know. Maybe a reference to T3 (Terminator 3)?
Old 04-06-2020, 05:21 PM
tvmaster2's Avatar
But there's no way to change it to something meaningful? lol. Alpha, Beta, Charlie, Tango?
How about STP-HD300?
Old 04-06-2020, 09:26 PM
I thing what he means is that if you telnet into the HD300 (username root, no password required) you will see that the Hostname is tango3. This can be seen in the file /etc/hosts. If you change the name of the localhost in the hosts file to whatever you want then you may be able to change that name.
But why does it really matter? I am not sure that you will really see this anywhere and that is NOT the server, name just the default client name. But you likely won't ever see that unless you go to this System Status area of the extender, which you shouldn't ever have to do.
Note - to edit this you likely have to use vi as that is the only editor available in the Linux version on the extender. And vi is freakin' painful to use.
You may be able to edit it on a PC and SCP it over to the extender, but I am not sure that an extender accepts SCP connections.
Note - here is the hosts file on an HD200:
STP-HD200[/etc]# cat hosts
127.0.0.1       localhost STP-HD200
To compare with what was posted above.
You also see this at the telnet login prompt. For a 300 you get "tango3 login:" whereas for a 200 you get "STP-HD200 login:"
Even if you can, you may not want to change this as there may be certain routines that depend on receiving tango3 to identify that it is an HD300. You may, or may not, be using such tools. I have written a groovy web utility that can list all of the SageTV clients and miniclients on your LAN and list the type of client. That utility will depend on this API extension which (I thiknk) was written by Slugger a few years back.
Old 04-06-2020, 10:59 PM
tvmaster2's Avatar
Thanks for this very thorough response. I guess youíre right - better just leave well enough alone. Itís just an odd thing to name it after the STP-HD200 seemed so logical.
Old 04-07-2020, 06:46 AM
dstanley's Avatar
dstanley dstanley is offline
You need to stop the HD300 BEFORE it connects to the server to get to the system settings.
In the Main Menu go to the Settings option.
Select Advanced Setup
Go to the Server section
Set 'Windows File Server' to Enabled
Set 'Windows File Server Workgroup' to WORKGROUP (This is usually the default of any Windows installation)
Set 'Windows File Server Network Name' to your choice - apparently Tango3 in your case
Back your way out and reconnect to your server as usual.
Hope this helps.
Old 04-07-2020, 10:26 AM
Hope this helps.
I don't think that's the same. Tango3 isn't the server name, it is the default client name for the HD300 extender.
Old 04-07-2020, 01:56 PM
dstanley's Avatar
Just changed mine from its current HD300 to LIVINGROOM and that is what is says under System Status now for HOSTNAME
Image of system status
Old 04-07-2020, 02:18 PM
tvmaster2's Avatar
Cool.
Old 04-07-2020, 03:42 PM
KryptoNyte's Avatar
KryptoNyte KryptoNyte is online now
When an extender connects to the SageTV Server, and I bring up the Web UI on a local PC, I typically click on the client name and just change it there. Is this having the same effect?
Old 04-07-2020, 04:27 PM
Where did you change it? In the hosts file or somewhere else?
If you telnet does it give you a prompt like:
LIVINGROOM login:
Old 04-07-2020, 04:28 PM
Not quite the same. I do that for all of my extenders as well and that is the best way to keep track of them in the web UI if you have a lot - like I do.
Old 04-09-2020, 03:43 PM
dstanley's Avatar
Works on my system - this is the Telnet screen from my MAC after I have changed the 'name' in the settings as my previous post.
System Info Content Different NetworkGuy SageTV Software 3 08-24-2017 06:40 AM
Version number in System Info gibsonpa SageTV Beta Test Software 4 03-05-2008 06:36 AM
STX-HD100 resolution per system info mcaron1234 SageTV Media Extender 4 03-04-2008 12:52 PM
Wrong disk space displayed in system info stevech SageTV Software 4 09-18-2007 04:03 PM
extremely long pause when entering system info davey_fl SageTV Beta Test Software 6 03-22-2004 07:14 AM
