Old 08-13-2010, 11:47 AM
SDeGonge's Avatar
SDeGonge SDeGonge is offline
Question Sage My Movies...Why Can't I Get This To Work?
I've got to be missing something simple here. Trying to install SMM, followed whatever instructions I could find, checked the threads but still having no luck. Everything I installed went smoothly but I just get a blank screen (no dvds listed). Let me tell you my install procedure and perhaps one of you will instantly spot whatever stupid mistake I made...
My system:
PC with SageTV 7, Win 7 32, Sage service & client. Also HD200s (see signature for more info)
Install Procedure:
- Stopped Sage service
- Installed "My Movies Collection Management", Server & Client
- Installed "SageMyMovies" plugIn
- Created "Folders.properties" file in C:\ProgramData\My Movies\FileStorage\SageTV\Properties.
- Contents of file contains a single line... DVD=E:\Video_DVD
- Rebooted everything (that was yesterday)
Today there are still no DVDs listed
Tried to Refresh Import Library - no luck
Do I need to do anything with the My Movies Tray Application or does the Sage PlugIn handle the scanning and downloading of cover art?
SageTV User Since 2009
Server Hardware: AMD FX6100, 6 Cores, 3.3GHz, 8GB RAM, TA970XE MB, 3TB HD, HVR-2250, HD-PVR, nVidia 9600GT 512MB
Server Software: SageTV 9, Windows 10 64bit, EventGhost
Client Hardware: HD200 x2, INT-422-3 & WR7 Remote
Service Provider: Cablevision (QAM to 2250, SamsungBox to HDPVR)
Old 08-13-2010, 12:01 PM
Tomahawk51's Avatar
Tomahawk51 Tomahawk51 is offline
I am definetly not an experienced user, but did you try this:
Open the "Collection Manager" application on the server. Go to Options and look for the Folder Monitor choice. Add the directories that hold your videos.
That should let My Movies scan and bring in your movies..and thus let them show in Sage.
If you already have movies showing in the Collection Manager list...disregard this.
Old 08-13-2010, 01:26 PM
SDeGonge's Avatar
Forgot to mention that I had already done this...
- Operating Type: Disabled
- Operating Location: Collection Management
- Monitored Folders: E:\Video_DVD
- Include folders added to Media Center Movie /DVD library: Unchecked
Old 08-13-2010, 01:29 PM
PLUCKYHD PLUCKYHD is offline
Do the movies show right in the collection manager? Did you try rebuilding the datafile in SMM options-->database?
The tray application needs to stay running for SMM to connect
Old 08-13-2010, 01:58 PM
SDeGonge's Avatar
No movies in the collection manager.
Just tried rebuilding - no change.
Tray app is running.
Old 08-13-2010, 02:10 PM
If not movies are in the collection manager then nothing is going to show in my app
are your movies in seperate folders? did you import your folders in the collection manager?
Old 08-13-2010, 02:25 PM
SDeGonge's Avatar
Didn't import the folders. I kinda thought that setting the Folder Monitoring in the tray app would automatically monitor for DVDs and add them. How would I import my movies? I see the "Add Titles" option but that looks like a manual process for each DVD.
Old 08-13-2010, 02:28 PM
Monitoring adds any new ones
go to file import-->Folder content and import your folders there (click on the main folder not the movie folder. That will add all of them. You will definately need to rebuild the datafile in sMM after doing that.
Old 08-13-2010, 02:53 PM
SDeGonge's Avatar
Duh - I knew it would be something simple. Worked like a charm. Now...in the future will I need to manually import new DVDs or should it automagically see them?
Thanks for the help
Old 08-13-2010, 02:56 PM
Thanks for the help
If you have the folder monitoring on (I recommend loose not strict) it will automatically pick up new movies added.
Keep in mind they will not show in Sagetv until the next automated import (which by default is every 2 hours if you havent' changed it).
cheers
Plugin:: Sage My Movies for Sagetv PLUCKYHD Sage My Movies 405 08-17-2010 09:17 AM
Sage 7 doesn't see movies in network shares rnadeau SageTV Beta Test Software 1 08-01-2010 09:28 AM
"Not Manual Recording" filtering doesn't work in SageTV's "Upcoming Movies" menu vince100 SageTV Customizations 3 11-23-2009 03:56 PM
Sage does not expect multipart movies carlgar SageTV Beta Test Software 3 07-07-2009 03:59 PM
How to play DIVX movies in Sage Boxpin SageTV Software 5 09-30-2005 09:29 AM
