Old 03-09-2021, 06:03 PM
mitchcecg mitchcecg is offline
help with Wiz.bin database is huge
my wiz.bin has grown to be 7,241,846kb is there a cleanup utility or some way for me to extract my favorites from it and import it into a new wiz.bin
Any info would be appreciated
BTW it causes an issue that the clients run out of memory and cant load
THANX
MITCH
If I had a son he would be a son of a Mitch
Old 03-11-2021, 11:40 AM
egeller egeller is offline
I did that back in 2012. I rebuilt the wiz.bin from scratch. I am not aware of any automated way to clean out / compress the wiz.bin.
I ran a manual process. Prerequisites include having the Jetty web server and SageTV web interface installed. You need that to export favorites.
I was going to list the steps here, but I am lazy. Then I remembered I've worked in IT for 40 years. I keep notes. I found the notes. They point me to this link. It is what I used. Good luck.
Interestingly, I searched the forum for 'recreate "wiz.bin"' and the search returned no results. Fascinating. I had a PDF of the posting and used that to find it.
SageTV Extender:3x HD200 1x HD300
Sage TV: 9.2.1, Standard STVi, Comskip Playback, Web Interface, 24 Hour Clock, SRE, YouTube2015, Playon
All in lovely Drexel Hill, PA
Old 03-16-2021, 02:44 AM
VCRUser VCRUser is offline
I looked at the linked instructions, and it said to export the wiz.bin as xml. In the web server I see an option to import xml but no export function.
(This is not something I need to do currently, but am saving the instructions for just-in-case).
Old 03-16-2021, 07:31 AM
graywolf's Avatar
graywolf graywolf is offline
From the Web UI
SageTV drop down, choose Recordings
Then above the list, you will see:
SageTV logoSage Recordings [XML]
Click on the XML icon
Old 03-16-2021, 08:44 AM
CptKirk CptKirk is offline
Hmm, I just tried this and got the following
It tried to load this page after clicking on the XML icon: http://htpc:8080/sage/Recordings?xml=yes
Showed this error
This site can’t be reached
The webpage at http://htpc:8080/sage/Recordings?xml=yes might be temporarily down or it may have moved permanently to a new web address.
ERR_INVALID_RESPONSE
Update...
I can go into Schedule Recordings-Favorites Manager and click on the orange XML icon for it to load page: http://htpc:8080/sage/Favorites?xml=yes
That prompts a download for favorites.xml, so I can get the favorites.xml download to work but for some reason the recordings.xml does not.
SageTV running on: Win7 SP1 64 Pro
SageTV 9.1.9.778 (32 bit)
Java 1.7.0_80 (32 bit)
OpenDCT 0.5.29 (Comcast Music channels set to FFmpeg)
Clients: HD300 (x2)
HDHR3-CC Prime 20190621 (Comcast CableCard) - 3 Tuners
Hauppauge 1950 STB SD (USB-UIRT Zone 1)
Hauppauge 1950 STB SD (USB-UIRT Zone 2)
Old 03-16-2021, 03:44 PM
Just to clarify, are you certain the size of your wiz.bin is 7,241,846kb? That would be over 7gb. For comparison purposes, mine is 66,308kb, or 66mb. If your wiz.bin is actually 7,241,846 bytes, that is good size but not huge. If it truly is over 7gb, that could certainly be the cause of your problem. I'd be surprised if the Sage server would even successfully start.
Server: MSI Z270 SLI Plus ATX Motherboard, Intel i7-7700T CPU, 32GB Memory, unRAID 6.9.2, SageTV & OpenDCT Dockers
Tuners: 2 x SiliconDust HDHomeRun Prime Cable TV Tuners
Clients: Multiple HD300 Extenders, Multiple Fire TV Stick 4K w/MiniClient
Old 04-10-2021, 05:09 PM
Just wanted to thank everyone for the reply
Mitch
HD Videos are huge! ericscottf Hardware Support 28 08-18-2010 11:58 AM
Huge Thanks pjt630 The SageTV Community 1 10-23-2008 07:09 PM
Is 8MB a huge wiz.bin? How to reduce? IVB SageTV Software 16 10-02-2005 05:11 PM
SageTV 2.1 is a huge mem/cpu hog? tankd0g SageTV Software 7 01-27-2005 10:21 AM
