Old 08-15-2010, 08:09 AM
tfurlong's Avatar
tfurlong tfurlong is offline
2 Blu-Ray Questions
First, I wanted to say I'm excited about Sage v7 and I love the new look of the interface!
Question #1
I think this topic has been covered before, but the solution isn't clear to me. I'm running Win7 x64, and I want to watch Blu-Rays through Sage using DVDFab Passkey (or AnyDVD HD could work, too). Can work without adding the drive as an import path and rescanning? I'd *love* to be able to insert a Blu-Ray and just play it, and I feel like I'm really close to being able to do that.
Question #2
What video setup options should I be using to watch a decrypted Blu-Ray that appears in the DVD/BD menu? My current set of options have it "failing to render the video portion".
Todd
Old 08-15-2010, 09:42 AM
Question #1
That isn't currently possible. It requires a scan to detect that it is a bluray in the drive.
Question #2
That sounds like a CODEC issue. More than likely, the disc you are trying to watch is VC-1, which I believe has some problems in the current eta builds. On Win7, H.264 BluRay's (which is MOST discs on the market) should play pretty much out of the box. VC-1, however, will have to be watched in an external player software, until sage gets the VC-1 playback fixed. (It's not presenting the VC-1 files correctly or something, preventing it from connecting to the proper decoders).
Old 08-15-2010, 10:41 AM
PLUCKYHD PLUCKYHD is offline
#1 will be possible soon in SMM I will not require a drive be added to the sage import library only that a movie be loaded in the drive.
Old 08-16-2010, 06:05 AM
tfurlong's Avatar
Fuzzy, thanks for the Codec tips.
Plucky, that sounds like exactly the behavior I'd like to see!
Old 08-16-2010, 03:25 PM
Naylia's Avatar
Naylia Naylia is offline
For now, if you only ever watch Blu-rays you don't have to rescan. You only need to rescan if you switch between DVDs & Blu-rays
You can find me at Missing Remote. Or playing FF XIV. For XLobby users: XLobby MC
Old 08-16-2010, 03:28 PM
Correct. One of the reasons I still have my HD-DVD drive hooked up. I play bluRays in the BluRay drive, and DVD's in the HD-DvD drive. Saves the rescanning if I switch out discs.
SageTV 7 playback of Blu-Ray on PC questions. sdsean SageTV Beta Test Software 31 03-19-2014 02:54 AM
Blu ray fix Deacon Crusher SageTV Beta Test Software 4 05-23-2010 11:04 PM
questions regarding m2ts and blu-ray lovingHDTV SageTV Software 7 12-08-2009 07:08 PM
HD200 and Blu-Ray ... some questions GCS2000 SageTV HD Theater - Media Player 16 11-11-2009 03:22 PM
To Blu-ray or not? KJake The SageTV Community 4 05-27-2008 07:55 PM
