Old 04-10-2006, 09:34 AM
New nVidia Driver upgrade for Linux
Found this on the nVidia site today.
Linux Display Driver - IA32
Version: 1.0-8756
Operating System: Linux IA32
Release Date: April 7, 2006
Release Highlights
Adds support for GeForce 7300, GeForce 7400 Go, GeForce 7600 and GeForce 7900 GPUs.
Added support for running OpenGL applications while the Composite X extension is enabled; see "The X Composite Extension" appendix for details.
Enabled hardware acceleration of the Render X extension by default.
Added "AddARGBGLXVisuals" X configuration option, so that OpenGL applications can render to X Windows' alpha channel.
Added Linux/i2c support to the NVIDIA kernel module; see the "i2c Bus Support" appendix for details.
Improved power management support with Linux >= 2.6.14 and added support for suspend-to-disk.
Added new "nvidia-auto-select" mode entry for use in the X configuration file; see description in the "Programming Modes" appendix.
Added support for GLX 1.4.
Added ability for OpenGL applications to span greater than 4096 pixels when in Xinerama.
Improved G-Sync support.
Fixed interlaced modes on CRTs.
Improved compatibility with the latest Linux 2.6 kernels.
