Old 01-27-2007, 10:29 PM
justindd justindd is offline
Sage Bug
I installed, but Sage doesn't even run.....
My TV card (PVR-250) works wonderfully if I simply
`./mplayer /dev/video0`
and in a separate terminal window do `ivtv-tune -c XX` to change channels
All of the errors look like java errors, but I am running the same java for everything as sage says to run 1.5.0 update 10.
I tried to run their stupid Gentoo CD, but it actually locks up my machine, and worse corrupted a partition on my hard drive (luckily I had it tarballed) before it even actually got into the installer, it was still booting.
I've attached the output from the server. This can't all be the version of Java I am running....
Either way, I'm going to try to see if I can get a refund and/or call 'the dog' if I can't get this thing going by the end of the week....this is piss poor installation support/instructions, especially considering they don't even point to or mirror packages to make things work, and MythTV is free and works just fine.....All I really wanted was placeshifter and MVP support, but at $100, it is definitely not worth the trouble for anyone who hasn't already made the purchase.
Output from sagetv_0.txt:
Sat 1/27 22:20:02.979 Error with DB file:java.lang.NullPointerException, attempting to restore backup.
Sat 1/27 22:20:03.220 detect 3
Sat 1/27 22:20:05.758 Error accessing file system:java.lang.NullPointerException
Sat 1/27 22:20:13.976 Error getting MAC address of:java.io.IOException: java.io.IOException: ifconfig: not found
Sat 1/27 22:20:13.976 MAC address was not able to be detected, using zero for the MAC!
Sat 1/27 22:20:15.345 Error getting MAC address of:java.io.IOException: java.io.IOException: ifconfig: not found
Sat 1/27 22:20:15.346 MAC address was not able to be detected, using zero for the MAC!
Sat 1/27 22:20:20.483 Error in MediaServerConnection of :java.io.EOFException
Sat 1/27 22:20:20.484 at sage.MediaServer$a.a(Unknown Source)
Sat 1/27 22:20:20.485 at sage.MediaServer$a.run(Unknown Source)
Sat 1/27 22:20:20.485 at java.lang.Thread.run(Unknown Source)
Sat 1/27 22:20:28.240 locale = en
Sat 1/27 22:20:31.273 Error invoking the method for: default:null|Action:"REM Hide some menus from nielm's dynamic menu system" of java.lang.NullPointerException
Sat 1/27 22:20:31.274 at sage.e.a(Unknown Source)
Sat 1/27 22:20:31.275 at sage.a1.a(Unknown Source)
Sat 1/27 22:20:31.276 at sage.e.a(Unknown Source)
Sat 1/27 22:20:31.277 at sage.e.a(Unknown Source)
Sat 1/27 22:20:31.277 at sage.UIManager.run(Unknown Source)
Sat 1/27 22:20:31.277 at sage.UIManager.try(Unknown Source)
Sat 1/27 22:20:31.278 at sage.be.a(Unknown Source)
Sat 1/27 22:20:31.278 at sage.be.access$700(Unknown Source)
Sat 1/27 22:20:31.279 at sage.be$1.run(Unknown Source)
Sat 1/27 22:20:31.280 Error invoking the method for: default:null|Action:"REM Check that at least the default category colors exist. If not, set the default values." of java.lang.NullPointerException
Sat 1/27 22:20:31.281 at sage.e.a(Unknown Source)
Sat 1/27 22:20:31.281 at sage.a1.a(Unknown Source)
Sat 1/27 22:20:31.282 at sage.a1.a(Unknown Source)
Sat 1/27 22:20:31.282 at sage.e.a(Unknown Source)
Sat 1/27 22:20:31.283 at sage.e.a(Unknown Source)
Sat 1/27 22:20:31.284 at sage.UIManager.run(Unknown Source)
Sat 1/27 22:20:31.284 at sage.UIManager.try(Unknown Source)
Sat 1/27 22:20:31.288 at sage.be.a(Unknown Source)
Sat 1/27 22:20:31.289 at sage.be.access$700(Unknown Source)
Sat 1/27 22:20:31.289 at sage.be$1.run(Unknown Source)
Sat 1/27 22:20:31.297 Hidden Extras are DISABLED
Sat 1/27 22:20:31.298 Error invoking the method for: default:null|ActionebugLog("Hidden Extras are " + If(GetProperty("enable_extras", false), "ENABLED", "DISABLED") ) of java.lang.NullPointerException
Sat 1/27 22:20:31.299 at sage.e.a(Unknown Source)
Sat 1/27 22:20:31.299 at sage.a1.a(Unknown Source)
Sat 1/27 22:20:31.300 at sage.a1.a(Unknown Source)
Sat 1/27 22:20:31.300 at sage.e.a(Unknown Source)
Sat 1/27 22:20:31.301 at sage.e.a(Unknown Source)
Sat 1/27 22:20:31.302 at sage.UIManager.run(Unknown Source)
Sat 1/27 22:20:31.302 at sage.UIManager.try(Unknown Source)
Sat 1/27 22:20:31.303 at sage.be.a(Unknown Source)
Sat 1/27 22:20:31.303 at sage.be.access$700(Unknown Source)
Sat 1/27 22:20:31.304 at sage.be$1.run(Unknown Source)
Sat 1/27 22:20:31.305 Error invoking the method for: default:null|Action:"REM Set a few variables to be used throughout." of java.lang.NullPointerException
Sat 1/27 22:20:31.306 at sage.e.a(Unknown Source)
Sat 1/27 22:20:31.306 at sage.a1.a(Unknown Source)
Sat 1/27 22:20:31.307 at sage.e.a(Unknown Source)
Sat 1/27 22:20:31.308 at sage.e.a(Unknown Source)
Sat 1/27 22:20:31.308 at sage.UIManager.run(Unknown Source)
Sat 1/27 22:20:31.309 at sage.UIManager.try(Unknown Source)
Sat 1/27 22:20:31.309 at sage.be.a(Unknown Source)
Sat 1/27 22:20:31.310 at sage.be.access$700(Unknown Source)
Sat 1/27 22:20:31.310 at sage.be$1.run(Unknown Source)
Sat 1/27 22:20:31.339 Error evaluating expression for attribute: default:null|AttributeontShowBack of java.lang.NullPointerException
Sat 1/27 22:20:31.342 at sage.a1.<init>(Unknown Source)
Sat 1/27 22:20:31.343 at sage.bu.<init>(Unknown Source)
Sat 1/27 22:20:31.343 at sage.UIManager.run(Unknown Source)
Sat 1/27 22:20:31.343 at sage.UIManager.try(Unknown Source)
Sat 1/27 22:20:31.344 at sage.be.a(Unknown Source)
Sat 1/27 22:20:31.344 at sage.be.access$700(Unknown Source)
Sat 1/27 22:20:31.345 at sage.be$1.run(Unknown Source)
java.net.SocketException: Socket closed
Sat 1/27 22:20:31.346 at java.net.SocketInputStream.socketRead0(Native Method)
Sat 1/27 22:20:31.347 at java.net.SocketInputStream.read(Unknown Source)
Sat 1/27 22:20:31.348 at java.io.FilterInputStream.read(Unknown Source)
Sat 1/27 22:20:31.348 at sage.be$a.run(Unknown Source)
Sat 1/27 22:20:37.348 Error getting MAC address of:java.io.IOException: java.io.IOException: ifconfig: not found
Sat 1/27 22:20:37.349 MAC address was not able to be detected, using zero for the MAC!
Sat 1/27 22:20:49.225 Error w/SageTV client connection:java.net.SocketException: Socket closed
Sat 1/27 22:20:49.228 MiniUI ServerSocket died from:java.net.SocketException: Socket closed
Sat 1/27 22:20:49.231 Error calling finishWatch from VF goodbye:java.lang.NullPointerException
Sat 1/27 22:20:49.440 Error calling finishWatch from VF goodbye:java.lang.NullPointerException
Old 01-28-2007, 09:06 AM
This is an OEM product that is really not supported except through OEM paid agreement. You can get help on the forum but not support. It is designed for the Gentoo isntall that seems to work for everyone BUT you so I wouldn't call it a bug. Are you using SUN java? It doesn't support any other version but Sun. There are also instructions and postings getting it running on other versions of Linux. And they just entered into an agreement with Linspire, which it runs on. You also need to make sure you meed the required hardware specs for a no-trouble installation. From the errors it looks like an issue with your network card not being recognized or configured.
Old 01-28-2007, 07:10 PM
Frey Server Down?
Perhaps the problem was related to a Frey server being down? I noticed that Wiz.bin used to be 1.0k and now it is 6.0MB....as though something is downloaded during activation and didn't work.....
But I still get all the same java errors, and further I cannot change channels.
Old 01-29-2007, 10:01 AM
_Demo_ _Demo_ is offline
Send a message via ICQ to _Demo_
Please try to install ifconfig then post another log.
_Demo_
Old 01-29-2007, 08:12 PM
Here is an updated log file following adding /sbin into the path (not mentioned in the instructions) also, I updated the libIVTVCapture.so with the one you suggested in the other thread. There is still at least one Java error, but the software is working now....
Sorry to be so gruff before, but it is very frustrating when the card is working, other Java apps are working, but sage won't run.
Mon 1/29 20:05:40.688 Error with DB file:java.io.IOException: Invalid DB file, o
nly partially saved., attempting to restore backup.
Mon 1/29 20:05:41.141 detect 3
Mon 1/29 20:05:41.733 createEncoder /dev/video0
Mon 1/29 20:05:41.734 verifying interface compatibility
Mon 1/29 20:05:41.734 Opened /dev/video0 with interface 1
Mon 1/29 20:05:41.745 Loaded
Mon 1/29 20:05:41.756 setInput0 0 0 1 1
Mon 1/29 20:05:41.756 updateColors0 b=128 c=128 h=128 s=128
Mon 1/29 20:05:56.409 Error in MediaServerConnection of :java.io.EOFException
Mon 1/29 20:05:56.410 java.io.EOFException
Mon 1/29 20:05:56.412 at sage.MediaServer$a.a(Unknown Source)
Mon 1/29 20:05:56.412 at sage.MediaServer$a.run(Unknown Source)
Mon 1/29 20:05:56.413 at java.lang.Thread.run(Unknown Source)
Mon 1/29 20:06:01.616 locale = en
Mon 1/29 20:06:02.692 Hidden Extras are DISABLED
Mon 1/29 20:06:05.506 Loading 600x450 image from file /opt/sagetv/server/STVs/Sa
geTV3/Background.jpg
Mon 1/29 20:06:05.926 Loading 256x78 image from file /opt/sagetv/server/STVs/Sag
eTV3/SageLogo256.png
Mon 1/29 20:06:05.974 Loading 586x47 image from file /opt/sagetv/server/STVs/Sag
eTV3/MenuBarLong.png
Mon 1/29 20:06:10.992 Loading 14x71 image from file /opt/sagetv/server/STVs/Sage
TV3/guideLeft.png
Mon 1/29 20:06:13.809 Loading 161x44 image from file /opt/sagetv/server/STVs/Sag
eTV3/MenuBarShort.png
Mon 1/29 20:06:30.002 Loading 29x26 image from file /opt/sagetv/server/STVs/Sage
TV3/OSDChUp.png
Mon 1/29 20:06:30.011 setInput0 0 0 1 1
Mon 1/29 20:06:30.012 updateColors0 b=128 c=128 h=128 s=128
Mon 1/29 20:06:30.027 new setChannel0 frequency 7220 (451250).
Mon 1/29 20:06:30.054 Loading 29x26 image from file /opt/sagetv/server/STVs/Sage
TV3/OSDChDown.png
Mon 1/29 20:06:30.151 Channel change succesful.
Mon 1/29 20:06:30.153 setEncodingProperties0 DVD Long Play
Mon 1/29 20:06:30.153 Set encoding property audiooutputmode to 0
Mon 1/29 20:06:30.154 Set encoding property audiocrc to 0
Mon 1/29 20:06:30.154 Set encoding property gopsize to 15
Mon 1/29 20:06:30.154 Set encoding property videobitrate to 4800000
Mon 1/29 20:06:30.154 Set encoding property peakvideobitrate to 6000000
Mon 1/29 20:06:30.155 Set encoding property inversetelecine to 0
Mon 1/29 20:06:30.155 Set encoding property closedgop to 0
Mon 1/29 20:06:30.155 Set encoding property vbr to 1
Mon 1/29 20:06:30.155 Set encoding property outputstreamtype to 10
Mon 1/29 20:06:30.156 Set encoding property width to 720
Mon 1/29 20:06:30.156 Set encoding property height to 480
Mon 1/29 20:06:30.156 Set encoding property audiobitrate to 384
Mon 1/29 20:06:30.156 Set encoding property audiosampling to 48000
Mon 1/29 20:06:30.157 Set encoding property disablefilter to 1
Mon 1/29 20:06:30.157 Set encoding property medianfilter to 3
Mon 1/29 20:06:30.157 Set encoding property fps to 30
Mon 1/29 20:06:30.157 Set encoding property ipb to 0
Mon 1/29 20:06:30.157 Set encoding property deinterlace to 0
Mon 1/29 20:06:30.158 Set encoding property aspectratio to 1
Mon 1/29 20:06:30.158 setEncoding0NewInterface
Mon 1/29 20:06:30.240 setup encoding /var/media/tv/video0TVTuner-0.mpgbuf
Mon 1/29 20:06:30.286 Loading 95x58 image from file /opt/sagetv/server/STVs/Sage
TV3/RecordingNow.png
Mon 1/29 20:06:31.257 Found next seq hdr code!
Mon 1/29 20:06:33.583 setInput0 0 0 1 1
Mon 1/29 20:06:33.583 updateColors0 b=128 c=128 h=128 s=128
Mon 1/29 20:06:33.603 setInput0 0 0 1 1
Mon 1/29 20:06:33.604 updateColors0 b=128 c=128 h=128 s=128
Mon 1/29 20:06:35.703 Closing down MiniPlayer
Mon 1/29 20:06:35.846 Error in MediaServerConnection of :java.io.IOException: Co
nnection reset by peer
Mon 1/29 20:06:35.846 java.io.IOException: Connection reset by peer
Mon 1/29 20:06:35.847 at sun.nio.ch.FileChannelImpl.transferTo0(Native Method)
Mon 1/29 20:06:35.847 at sun.nio.ch.FileChannelImpl.transferToDirectly(Unknown
Source)
Mon 1/29 20:06:35.847 at sun.nio.ch.FileChannelImpl.transferTo(Unknown Source)
Mon 1/29 20:06:35.848 at sage.MediaServer$a.a(Unknown Source)
Mon 1/29 20:06:35.848 at sage.MediaServer$a.for(Unknown Source)
Mon 1/29 20:06:35.848 at sage.MediaServer$a.run(Unknown Source)
Mon 1/29 20:06:35.849 at java.lang.Thread.run(Unknown Source)
Mon 1/29 20:06:47.351 Loading 26x25 image from file /opt/sagetv/server/STVs/Sage
TV3/down.png
Mon 1/29 20:06:48.702 Loading 27x25 image from file /opt/sagetv/server/STVs/Sage
TV3/up.png
Mon 1/29 20:07:08.332 Loading 24x29 image from file /opt/sagetv/server/STVs/Sage
TV3/left.png
Mon 1/29 20:07:08.432 Loading 25x27 image from file /opt/sagetv/server/STVs/Sage
TV3/right.png
Mon 1/29 20:07:08.447 Loading 15x71 image from file /opt/sagetv/server/STVs/Sage
TV3/guideRight.png
Mon 1/29 20:07:10.518 BEGIN: Sort video playlists.
Mon 1/29 20:07:10.520 END: Sort video playlists. Sorted 0 playlists. Total Time
= '2'
Mon 1/29 20:07:10.600 Loading 30x26 image from file /opt/sagetv/server/STVs/Sage
TV3/OSDPlay.png
Mon 1/29 20:07:10.693 Loading 30x26 image from file /opt/sagetv/server/STVs/Sage
TV3/OSDRecord.png
Mon 1/29 20:07:10.704 Loading 146x146 image from file /opt/sagetv/server/STVs/Sa
geTV3/MarkerInfo.png
Mon 1/29 20:07:12.052 setInput0 0 0 1 1
Mon 1/29 20:07:12.052 updateColors0 b=128 c=128 h=128 s=128
Mon 1/29 20:07:12.068 new setChannel0 frequency 884 (55250).
Mon 1/29 20:07:12.262 Channel change succesful.
Mon 1/29 20:07:12.263 setEncodingProperties0 DVD Long Play
Mon 1/29 20:07:12.264 Set encoding property audiooutputmode to 0
Mon 1/29 20:07:12.265 Set encoding property audiocrc to 0
Mon 1/29 20:07:12.267 Set encoding property gopsize to 15
Mon 1/29 20:07:12.268 Set encoding property videobitrate to 4800000
Mon 1/29 20:07:12.268 Set encoding property peakvideobitrate to 6000000
Mon 1/29 20:07:12.269 Set encoding property inversetelecine to 0
Mon 1/29 20:07:12.270 Set encoding property closedgop to 0
Mon 1/29 20:07:12.271 Set encoding property vbr to 1
Mon 1/29 20:07:12.271 Set encoding property outputstreamtype to 10
Mon 1/29 20:07:12.272 Set encoding property width to 720
Mon 1/29 20:07:12.272 Set encoding property height to 480
Mon 1/29 20:07:12.273 Set encoding property audiobitrate to 384
Mon 1/29 20:07:12.274 Set encoding property audiosampling to 48000
Mon 1/29 20:07:12.275 Set encoding property disablefilter to 1
Mon 1/29 20:07:12.276 Set encoding property medianfilter to 3
Mon 1/29 20:07:12.277 Set encoding property fps to 30
Mon 1/29 20:07:12.277 Set encoding property ipb to 0
Mon 1/29 20:07:12.278 Set encoding property deinterlace to 0
Mon 1/29 20:07:12.278 Set encoding property aspectratio to 1
Mon 1/29 20:07:12.278 setEncoding0NewInterface
Mon 1/29 20:07:12.369 setup encoding /mnt/3ware/sage/10472_2_0129_2007-0.mpg
Mon 1/29 20:07:13.153 Loading 96x97 image from file /opt/sagetv/server/STVs/Sage
TV3/RecordAny.png
Mon 1/29 20:07:14.326 Loading 16x13 image from file /opt/sagetv/server/STVs/Sage
TV3/OSDVolOn.png
Mon 1/29 20:07:14.348 Loading 9x15 image from file /opt/sagetv/server/STVs/SageT
V3/OSDVolSlider.png
Mon 1/29 20:07:14.355 Loading 29x26 image from file /opt/sagetv/server/STVs/Sage
TV3/OSDReplay.png
Mon 1/29 20:07:14.366 Loading 30x26 image from file /opt/sagetv/server/STVs/Sage
TV3/OSDRew.png
Mon 1/29 20:07:14.376 Loading 30x26 image from file /opt/sagetv/server/STVs/Sage
TV3/OSDStop.png
Mon 1/29 20:07:14.390 Loading 30x26 image from file /opt/sagetv/server/STVs/Sage
TV3/OSDFwd.png
Mon 1/29 20:07:14.401 Loading 29x26 image from file /opt/sagetv/server/STVs/Sage
TV3/OSDSkip.png
Mon 1/29 20:07:14.446 Loading 35x26 image from file /opt/sagetv/server/STVs/Sage
TV3/OSDChDisplay.png
Mon 1/29 20:07:14.632 Found next seq hdr code!
Mon 1/29 20:07:16.131 Loading 8x8 image from file /opt/sagetv/server/STVs/SageTV
3/OSDStatusPlay.png
Mon 1/29 20:07:16.165 Loading 30x26 image from file /opt/sagetv/server/STVs/Sage
TV3/OSDPause.png
Mon 1/29 20:07:19.694 new setChannel0 frequency 980 (61250).
Mon 1/29 20:07:19.832 Channel change succesful.
Mon 1/29 20:07:19.835 switch encoding /mnt/3ware/sage/18254_3_0129_2007-0.mpg
Mon 1/29 20:07:19.850 Closing down MiniPlayer
Mon 1/29 20:07:20.136 Found next seq hdr code!
Mon 1/29 20:08:16.688 new setChannel0 frequency 7220 (451250).
Mon 1/29 20:08:16.822 Channel change succesful.
Mon 1/29 20:08:16.838 switch encoding /mnt/3ware/sage/11207_62_0129_2008-0.mpg
Mon 1/29 20:08:16.846 Closing down MiniPlayer
Mon 1/29 20:08:17.226 Found next seq hdr code!
Old 01-30-2007, 10:12 AM
You can ignore those errors.
_Demo_
