Old 10-01-2007, 09:47 AM
galeo galeo is offline
Feature/Utility Request - Interactive Bookmarks
I would be great if someone could develop a utility with the following functions/features (unless something like this already exists)
  • Ability to create bookmarks within recordings or shows that you know you might want to watch again - or share it with someone else.
  • Ability to create searchable tags with each of the bookmarks.
These could be saved into a <bookmark> tag in the xml files created by the xml generator. The way I see it work is you are watching a show and you see an important scene (say an amazing goal by Ronadino, or an action sequence in a movie etc.) you use a key (say ctrl+B)... the show pauses and you can optionally enter some words to be associated with that bookmark.
  • Bookmarks should show up as some colored lines in the display bar.
  • There should be "search all bookmarks" function - which can look through all the xml files and match the word(s) and list the recordings that match.
  • Be able to skip to the next bookmark
Some advanced applications could be:
  • Create "begin" and "end" bookmarks within a show and then the "convert" tool could use these bookmarks to convert the shows - rather than the current process of entering start time in seconds and the duration in seconds...
  • Manual commercial skipping... modify the comskip feature to become a subset of the bookmark feature with predefined tag names. So while watching a show - you could manually hit a key (specifically for commercial begin and end) Another option would be to make manual adjustments to the comskip values that were generated by the detection algorithms.
  • Warn users before deleting shows that have embedded bookmarks.
  • Deleting/renaming and moving/adjusting bookmarks.
  • Be able to share these bookmarks with other users. For example there could be forums for certain TV shows that people watch regularly -and people can "customize" their show with bookmarks and tags. Might encourage people to get SageTV.
Plugin: Web User Interface for SageTV 2.2-6.6 (V2.25 18 Sep 2009) nielm SageTV Customizations 2644 10-24-2016 10:18 AM
Feature Req: Summer's here, time to request movie channel IR selection again tvierling SageTV Software 1 06-24-2007 11:27 PM
Interactive Digital Cable Ready oddjob General Discussion 2 03-09-2007 07:58 PM
Feature Request following 3.0.3 beta snoopy SageTV Beta Test Software 83 03-31-2006 03:38 PM
Reply to request for TV Guide during playback Crashless SageTV Software 1 03-12-2005 02:47 PM
