Old 05-24-2008, 12:33 PM
pvr599 pvr599 is offline
HD100 Firmware update not working
Hey guys,
I've checked around and couldn't find the answer to this. I just got my HD100 and wanted to update the firmware. I followed the instructions here:
http://forums.sagetv.com/forums/show...797#post253797
When I click on Check for Updates it says no updates available. Currently I have 20080204 0. I must be doing something wrong.
I one kinda off the subject question. I read about how some have changed the aspect ratio to 1080p and 720p. The only way I saw to change the picture was the Aspect button on the remote. I'm getting really a really pixally picture and I'm not sure if it's the aspect ratio or using the composite cables that came with it.
Any help would be appreciated. Thanks.
Dana
Diehard SageTV User
Hardware:
Vizio M550NV 55",GA-H67A-UD3H-B3 LGA 1155, Intel i3, 4Gb DDR3, USB-UIRT, 2x Colossus, 1 HDHR, HD100, HD200
Software - Win7 64 bit, SageTV 7.1.9, Java v6, HD100 firmware v20100212-0, HD200 firmware 20100909 0
Old 05-24-2008, 12:36 PM
Originally Posted by pvr599 View Post
Hey guys,
Dana
You need to go to the firmware update screen and type 2382 on the remote then the title at the top of the screen will change to indicate "beta firmware" then check for updates.
Old 05-24-2008, 01:27 PM
gveres gveres is offline
You have the latest non-beta firmware.
DO NOT UPDATE to the lastest beta firmware if you have any HD content you want to playback and you are using SPDIF for your audio. The latest firmware is bad.
[edit: to make this post more clear, 5/23 was bad, 5/19 is good.]
Old 05-24-2008, 02:14 PM
toricred's Avatar
toricred toricred is offline
The bad version of the beta firmware appears to have been taken down. The 5/19 version is now the latest beta available.
Old 05-24-2008, 05:56 PM
Thank you!!
Diehard SageTV User
Hardware:
Notice: DirecTV D11 update and SerialControl (TV Translator users) IncredibleHat Hardware Support 1 06-04-2008 09:17 AM
auto aspect problem on HD100 bigdessert SageTV Customizations 3 05-04-2008 08:15 PM
new SageTV user with HD100 Question jelentz@gmail.c SageMC Custom Interface 8 03-13-2008 01:04 PM
The official, "SageTV is working well for me!" thread jbarr General Discussion 21 06-21-2007 06:33 PM
Program Guide Update Time? Lastb0isct SageTV EPG Service 2 07-17-2006 09:52 PM
