Old 06-07-2008, 06:29 PM
Qusix Qusix is offline
Question Do I need to Manually Setup Each Client Interface?
I have SageTV Media Center Setup with the SageMC Interface. I installed Sage Client on my PC and I am able to connect to the server and watch TV. However it is not showing the same SageMC interface that is on the PC running the Server. It is showing the default interface. I thought they would show the same interface. Do I have to install the same files for SageMC on the Client also?
I have also ordered the media extender and should have it on Monday. Will I also have to install the SageMC files on it?
Old 06-07-2008, 06:42 PM
Yes, you'll need to install SageMC on each client.
As for the extenders, if SageMC is setup on the server, when you first connect the extender, it should clone the server's config IIRC. At most you'll have to go in and select the SageMC STV from the extender.
Sage Client Questions camus SageTV Software 15 05-14-2012 07:00 AM
Just what is a SageTV extender? What is a thin client or a thin server? gerdi SageTV Media Extender 108 03-11-2009 08:44 PM
New client setup issue Lucas SageTV Software 2 01-10-2008 11:31 PM
Live Tv and Sage Client behavior mattridings SageTV Software 7 12-26-2007 04:59 AM
SageTV Client: Keeping UI in Sync with MVP sjrx0213 SageTV Software 3 02-09-2007 05:21 PM
