Old 01-02-2009, 11:35 AM
lmeyer lmeyer is offline
Can't update firmware
I updated my firmware when I first set up the HD200, but I did not know to enter 2382 while updating. I have been trying to re-run the update, but get a no updates available message. I have tried unplugging the HD200, pressing the delete key, and plugging the HD200 back in. When I try to update my firmware, it still says no new updates. What am I missing?
Old 01-02-2009, 11:40 AM
QueOnda's Avatar
QueOnda QueOnda is offline
You don't push 2382 while updating....When your in the screen, you push 2382, then you should see the word BETA in the 1st sentence. After that you can check for updates.
Old 01-02-2009, 04:58 PM
Thanks that did it. Now I'm back to my original problem, but I'll open a new thread for that!
HD100 Firmware update not working pvr599 SageTV Media Extender 4 05-24-2008 05:56 PM
Cn't update HD firmware, anyone do this with Vista? carlgar SageTV Media Extender 12 12-21-2007 07:45 AM
Firmware Update eded9698 SageTV Media Extender 2 12-20-2007 09:37 PM
How to update the firmware on the Media MVP msmith8228 SageTV Media Extender 2 01-15-2007 01:32 AM
