I just upgraded my XP machine to Windows 7 32bit. CD was dead on with XP, with Win7 it's all over the place. Any ideas why? Only change was OS.
If the accuracy isn't as good as it was the first thing I'd look at is the .ini file. Do you make any customizations that were not carried over to W7? Check the settings to make sure CommercialDetector is pointed at the right comskip.exe and comskip.ini. If none of that works set the debug level to Trace and attach a logfile after it's processed a recording or two.
Commercial Detector Not Working On Client | ptzink | SageTV v7 Customizations | 5 | 04-17-2011 07:29 AM |
Commercial detector on client | gabrielcab | SageTV v7 Customizations | 10 | 03-29-2011 01:26 PM |
is it possible to have commercial detector use VPrj files? | freewheeling | SageTV v7 Customizations | 7 | 03-23-2011 01:26 PM |
Convert with Commercial Detector | rickybee | SageTV v7 Customizations | 2 | 02-26-2011 08:53 AM |
How do I access Commercial detector ui ? | rnadeau | SageTV v7 Customizations | 2 | 08-21-2010 12:24 PM |
