HD300 Composite Connector Question
Is the Composite / component connector on the hd300 proprietary?
If not, could you recommend a replacement? Thanks |
I'd be interested in knowing the answer to this as well. My connector is very, very flaky. If my extender get's moved or the cable is giggled, there is a high probability my video drops out.
As a side note, would there be any way to repair it? |
Is your res 1080p or 1080i. I have mine set to 1080i cause 1080p was flaky. I'm running composite because I got a new Vizio TV that is not letting me select 3D manually on HDMI, but firmware update is out there to fix it, just hasn't reached my TV yet.
WMC Server: Windows 8.1, Dell PowerEdge T110, 12G ram, 2x2TB hd, 4xHDHR, HDHR Prime, 1000Mb/s Provider: Suddenlink Cable |
I have the same problem, if I wiggle the connector, I get audio static/hum.
Other than finding one on eBay, you can try a repair if your handy with soldering. See this thread: http://forums.sagetv.com/forums/show...53&postcount=5 I have not confirmed if the printout or the connector mentioned is correct, so your on your own... |
Composite Connection
Okay, Took a while to get back here.
Thought my HDMI connector went bad but found it to be the cable. Read in one of the forums that the HD300 HDMI output is on the week side so replaced a 6 foot cable with a 3 foot cable and all is well. Still wondering if the composite connection is proprietary since I can not locate the original breakout cable. Thanks for your replies. |
Mike Janer SageTV HD300 Extender X2 Sage Server: AMD X4 620,2048MB RAM,SageTV 7.x ,2X HDHR Primes, 2x HDHomerun(original). 80GB OS Drive, Video Drives: Local 2TB Drive GB RAID5 |
Source for HD300 Breakout Connector | Sagebrush | SageTV HD Theater - Media Player | 4 | 02-18-2011 04:23 PM |
so how does the HD300 work with composite out? | SomeWhatLost | SageTV Media Extender | 15 | 01-11-2011 11:33 PM |
HD300 composite and HDMI work together now? | Brent94Z | SageTV Media Extender | 2 | 01-08-2011 09:29 AM |
HD300 Black and White via Composite | HokiePerogi | SageTV HD Theater - Media Player | 5 | 12-21-2010 08:37 PM |
HD300 Color/Saturation over Composite Video | reggie14 | SageTV Media Extender | 6 | 09-24-2010 10:57 PM |
