SageTV EPG Service Discussion related to the SageTV EPG Service used within SageTV. Questions about service area coverage, channel lineups, EPG listings, XMLTV, or anything else related to the service or programming guide data for SageTV should be posted here. |
Schedules Direct EPG Channel Mapping
Hello,
I'm new to SageTV, coming from Windows Media Center. Installed v9 on Linux Mint (Ubuntu) and I'm running into EPG issues. I have FIOS in Central Florida with HDHomeRun Prime cable card turner and the Schedules Direct EPG does match up with my scanned channels. Do I have to map all the channels manually? MCE did this automatically somehow. |
I got this working. I wasn't using OpenDCT which solved the problem. I couldn't get it to work without using OpenDCT. Was trying to go without it since SageTV sees the tuner and plays fine without it. The guide doesn't work properly though for the channel mappings.
SageTV can handle the older non-cable card HDHRs directly, but does not have built in support for cable card tuners. My guess is that Sage tried to use your Prime as a clear QAM tuner, but couldn't find any channels. Yes you need an external app to handle the Prime with cable card - OpenDCT is probably best choice right now and has the best support.
Tags |
channel mapping, epg |
How to Migrate to Schedules Direct? | reggie14 | SageTV EPG Service | 51 | 10-15-2017 07:34 PM |
Plugin: Schedules Direct EPG (not for v9) | Slugger | SageTV v7 Customizations | 851 | 07-19-2017 07:48 AM |
Using Schedules Direct in UK | jamesdisco | SageTV United Kingdom | 28 | 02-06-2017 11:54 AM |
Schedules Direct Plugin Issue | rickgillyon | SageTV v9 Customizations | 20 | 09-25-2016 12:03 PM |
Schedules Direct or what? | Ryel | SageTV EPG Service | 6 | 01-25-2008 03:03 PM |
