Old 10-18-2021, 11:41 AM
nyplayer nyplayer is online now
Problem moving Thumbnail folder ....
The android minilient has a problem with long thumbnail names where it freezes .... so I am trying to move the thumbnail folder but Sage seems to have a mind of its own.
This is what I have in Sage Properties ...
ui/thumbnail_folder=R\:\\thumbnails
this what sage translates it to.
C:\Program Files\SageTV\SageTV\R:\thumbnails
Of course it does not exist. So I have no Channel Icons or thumbnails.
The Problem is the default just adds to the filename length ...
C:\Program Files\SageTV\SageTV\GeneratedThumbnails
Old 10-18-2021, 03:20 PM
wnjj wnjj is online now
It looks like the 'thumbnail_folder' property is just that, a folder. It gets added onto a default "cache" path which is where the "C:\Program Files\SageTV\SageTV" comes from.
https://github.com/google/sagetv/blo...ker.java#L1089
Looking further, it seems that if sage.paths.cache is not defined it falls back to the Java system var user.dir (which is the install dir). That is likely where the extra comes from.
Windows Installer
Old 10-18-2021, 04:12 PM
Is there a way to define the sage cache path ? to another drive.
Old 10-18-2021, 07:01 PM
I donít think so without a code change. Those properties are defined inside the JVM and I didnít see any place where that one gets set.
Windows Installer
Old 10-18-2021, 08:17 PM
I don’t think so without a code change. Those properties are defined inside the JVM and I didn’t see any place where that one gets set.
Thanks I shortened the length of the default "GeneratedThumbnails" and made it just "ART" that seems to have helped the crashes.
ui/thumbnail_folder=art
I finally just decided to move the Installation out of the main drive Installed in R:\SageTV this shortened the thumbnails names by a lot... Plus I did not want all these thumbnails on my main os drive.
Question About Moving TV Shows to Video Folder will SageTV Software 5 07-30-2014 04:17 PM
Odd problem with DVD Art Cover (folder.jpg). SHS SageTV Software 2 01-04-2014 07:26 AM
Videos by Folder problem gwynp SageTV Software 10 08-05-2009 11:00 PM
Fan Art folder problem.... Chaos~Theory SageMC Custom Interface 0 04-11-2009 09:48 PM
Moving away from a rec. folder Franc SageTV Software 5 02-10-2009 06:41 AM
