Old 03-19-2023, 11:05 AM
How do you fix a zero duration file?
I have recently had some issues with files that have been imported. When I look at them in the web UI they show as being 0 duration. These files are actually over 2 hours long. They are MP4 files.
How do I fix this? Is there a simple edit with BMT or the web UI? When I look at the Web UI the only thing you can edit is :
File start time: [XX] seconds [earlier/later] than Airing Start Time
Here is what it shows under the Aired part of the web UI detail file info:
Aired: Mar 18, 2023 2:22 PM - 2:22 PM
Duration: 0 m
I tried putting in a duration of the correct time, but that didn't work.
Old 03-19-2023, 11:26 AM
jusjoken jusjoken is offline
I seem to recall that you do a touch on the file so it updates its time stamp and sage will then re determine the duration.
k
Old 03-19-2023, 02:43 PM
graywolf's Avatar
graywolf graywolf is offline
Or I have seen if there are a bunch subtitles to them (or at least for me with mkv files) then Sage tends to barf on them
Old 03-19-2023, 04:54 PM
I tried a touch and it updated the file date and time and that didn't help.
Old 03-19-2023, 05:08 PM
No subs on this file.
Old 03-19-2023, 05:29 PM
I've been seeing this increasingly with imported videos as well. Playback is affected as well (at least on a Windows client), seeking doesn't work at all. And if you stop and restart one of these videos, it will always start at the beginning again.
Old 03-19-2023, 05:35 PM
I find when I run into situations like that, I need to re-encode the file via Handbrake to a more friendly container/codec that Sage likes.
How to get dvd duration davidb SageTV Github Development 10 04-16-2016 09:50 AM
Wrong DVD duration MovieFreak Sage My Movies 14 06-01-2011 12:09 PM
Video Orbiting Duration rnadeau SageTV Software 0 01-10-2011 12:47 PM
VBR MP3 duration miscalculation nielm SageTV Beta Test Software 8 01-18-2007 06:51 PM
