SageTV HD Theater - Media Player Discussion related to using the SageTV HD Theater as a Media Player, i.e.: in use while not connected to a SageTV server. Questions, issues, problems, suggestions, etc. relating to using a SageTV HD Theater as a Media Player should be posted here. Use the SageTV Media Extender forum for issues related to using it while connected to a SageTV server. |
Some questions prior to purchase.
I have a windows home server (WHS) configured for media sharing. My XB360 sees it on the network without any difficulty.
When I connect the SageTV HD theater to my home network and HDTV will it see my WHS automatically and find files in the shared folders? Do I need to purchase the sagetv software with the sagetv media player? Will the media player also play h.264 AVCHD video clips? Thanks in advance. Ferd |
If you only using the HD200 as a media player, then you don't need the sagetv software.
The HD200 will play h.264 AVCHD files.
Server: HP AMD64 dual core running Win7 64bit (MCE disabled) with 4G memory Tuners: 2 PVR-500(disabled), 3 HDHR and 1 HDPVR Clients: 2 HD200 and 1 HD100 TV: 70" and 52" and 42" Media Storage: ReadyNas 8TB Recording media: 300GB + 200GB+ 250 GB Network: Gigabit backbone' Thanks to all the developers who work on SageMC, code, utilities and plug-ins to make SageTV better!!! ![]() |
Will the HD200 identify my WHS automatically? Is 100mb networking fast enough for streaming video content?
Yes it will find it. On the first startup of the hd200, you have to go to the settings menu and pick the server. From then on, it will find the server.
No, a 100mb router/switch will give you grief. I would go to 1 gb.
WHS server, PVR150, PVR500, 2 HD200, 2 placeshifter laptops |
NO, not in media mode. You have to go select a directory/folder on the network, then scan the files so they always show up. If you only using the WHS and a HD200, then a 100mb will be fine. I had a HD100 and a HD200 playing at the same time while recording 4 HDHR HD shows (20MB each) with no problem.
Yes, 100Mb is fine provided you have a good NIC (on your server) and switch. Intel NIC's are the best, and a dedicated switch is usually better than the ones included in home firewall/router.
Server: ASUS Q87M-E, Intel i5-4590S, 8GB RAM, DR-400-6 RM case, 2x Addonics Disk Array 3SA, 9TB disk, 2x HDHomeRun, HD-PVR 1212, Win8.1-64bit, Sage 9 Client 1: HD300 on Panasonic Plasma TC-P50ST60 Client 2: HD300 on Vizio 40" Others: Sage Client & Placeshifter |
Pre-Purchase Questions | wvpolekat | General Discussion | 12 | 04-09-2007 10:05 PM |
Newbie questions regarding which bundle to purchase (I have DirecTV). | rusmo | Hardware Support | 0 | 05-15-2006 12:20 PM |
Radio Times listings prior to 6:00am | srcurtis | SageTV United Kingdom | 0 | 07-24-2004 01:23 PM |
Need a couple of questions answered before I purchase SageRecorder | fathero | SageTV Recorder Software | 3 | 11-11-2003 04:38 PM |
Couple questions before I purchase | fasttech | SageTV Software | 2 | 05-15-2003 05:17 PM |
