Old 01-25-2010, 11:19 PM
J3G J3G is offline
should I change from 1080i to 720p on hd-pvr for Placeshifter playback
I was told by SageTV customer service to change my hd-pvr to 720p so that their Placeshifter software will work for me. I have been recording everything in 1080i up to this point.
Should I follow their advice and change to 720p? or should I find another solution?
I typically output to 1080p 46" LCD or 1080p 106" projector
Old 01-25-2010, 11:54 PM
Slugger Slugger is offline
You really don't have a choice if you want to watch HD-PVR recordings via Placeshifter. The current transcoder used by Placeshifter simply cannot process 1080i recordings.
I, too, have a 46" LCD and I don't really notice the difference between 720p and 1080i - all I know is that it all looks much better than the SD alternative. Mind you, I'm not a hardcore video guy so I'm sure others will tell you there is a huge difference between 720p and 1080i and that you shouldn't sacrifice the PQ. Bottom line, if you want to watch the recordings via Placeshifter then you simply don't have a choice (at this time).
Twitter: @ddb_db
Capture: 2 x Colossus
STB Controller: 1 x USB-UIRT
Recommend a video card for 1080i playback. JGAM Hardware Support 17 10-03-2008 05:24 PM
720p vs 1080i with Hauppauge HD PVR mces97 Hardware Support 7 08-29-2008 10:29 AM
HD-PVR use 720p for PC clients MrD SageTV Software 2 08-27-2008 02:05 AM
HD-PVR works at 720p, but no 1080i!!! Eckwell Hardware Support 0 06-06-2008 06:59 PM
No problem 1080i .ts, stuttering 720p krustyjonez SageTV Beta Test Software 0 08-17-2005 07:37 AM
