Old 08-03-2003, 03:54 PM
PaulModz PaulModz is offline
wiz.bin corruption?
I have about 15 or 20 favorites selected in Sage. Whenever I add, change or remove a favorite, Sage will shoot to 100% CPU usage for 1 to 2 munutes. In addition, when I start Sage, it uses 100% CPU for over 5 minutes, and is using 180MB of memory at that point.
I have been able to consistenly get this to happen by performing the following steps:
shut down sage
delete my wiz.bin and wiz.bak files
restart sage
wait until EPG download is done
start adding favorites
The first few favorites that I add go smoothly, but as I continue to add favorites, Sage takes longer and longer to resolve conflicts, until changing the watched status on a single show can cause Sage to use 100% CPU for several minutes, with Sage using over 300MB of memory and it never goes back down.
Is this expected behavior? I have an Athlon XP 2400+ with 512MB, so its not like I'm at the bottom end of the requirements.
I've also noticed that sometimes Sage seems to refuse to record anything when it runs into conflicts. I can clearly see in the guide that multiple favorites are on during a time period, but that time period is blank in my recording schedule, and Sage never asked me which one I would prefer to record.
Am I right in assuming that once CPU usage has gone back down after adding a favorite, the schedule should be accurate, or will Sage go back later and resolve conflicts?
Old 08-03-2003, 04:20 PM
fidget's Avatar
fidget fidget is offline
What version are you running? The 100% CPU and wiz.bin corruption problems are suppose to be fixed with 1.4.7 Beta. I have had no problems with the stability of the Beta, but YMMV.
-Jonathan
Old 08-03-2003, 04:41 PM
I'm using 1.4.5, I didn't even notice that 1.4.7 came out this week. I'll upgrade and see what happens.
Old 08-03-2003, 05:13 PM
Upgrading to 1.4.7 didn't help. I can easily cause Sage to spend minutes at a time processing favorites changes, and Sage routinely uses up to 300MB of memory. In addition, I sometimes have a completely blank recording schedule on start up.
The EPG Guide drawing seems to have some problems in 1.4.7 as well.
Old 08-04-2003, 08:01 AM
dkardatzke's Avatar
dkardatzke dkardatzke is offline
SageTV Co-Founder
Paul,
Please e-mail your log file to support@freytechnologies.com so we can have a detailed look at the problem.
Dan Kardatzke, Co-Founder
SageTV, LLC
Old 08-04-2003, 11:03 AM
salsbst's Avatar
salsbst salsbst is offline
Paul, I'm sure Frey will help you out... but for me, the solution to these same problems was to set "disable_phase1_optimization=false" in the sage.properties file. THis has the effect that sometimes the first airing of a favorite isn't recorded, but the beneficial effect that SageTV works again for me.
Old 08-04-2003, 05:49 PM
Dan,
I've sent my log files to you guys, but I must say I was shocked to see that one of the log files was 183MB, and another was 368MB, is that a problem? (They all zipped down to 3.5MB).
Also, Sage seems to be working fine now. Yesterday, even changing the channel caused me to have 100% CPU for a few minutes, now I can add a favorite with no noticable CPU usage. So, whatever is going on, it seems related to adding a lot of favorites in a very short period of time.
Old 08-05-2003, 06:30 PM
Narflex's Avatar
Narflex Narflex is offline
Sage
I took a look at the logs. There was a debug statement I left in there that caused the logs to get really big under a certain circumstance, that itself was slowing down Sage. It's fixed for the next build. That along with the fixes in 1.4.7 you have now, should solve the problem.
Jeffrey Kardatzke
Google
Founder of SageTV
