Old 02-28-2006, 11:18 PM
bazan bazan is offline
Question some question 2 pvr500mce related to recording schedule
Hi i have a system with sagetv 4.1.3 and 2 pvr500mce, it works great it do multiple recording at the same time etc etc, but lets say i want to record 4 channels 24/7 , how do i setup the recordings so the files breaks every hour?
i plan to put record from 01:00 to 02:00 then 02:01 to 03:00 and on and on. but im loosing 23 minutes a day .
i now i can record large files then split with virtualdub but its a lot of work when it could be done automatically.
also is there a way i can import a recording list to sagetv? i mean is the recording schedule saved somewhere so i can make an aplication to make a recording file?
Regards Me
Old 02-28-2006, 11:35 PM
If you mean via Timed Recordings, try removing the 1 minute breaks.
Are you using XMLTV? What does the Program Guide currnetly say for your 4 channels? If you aren't recording actual TV shows, perhaps you could create your own listings & make up the same 4 'show' names & make them 1 hour shows that are on all the time for the 4 channels, then set up a Favorite for the show. (Just an idea...)
You can export the schdule to a text file via the scheduler_export_file=<filename> property, but that is just an output file. SageTV creates its own schedule.
Old 03-01-2006, 01:07 PM
hi tnx for replying
where does sagetv save his schedule, maybe i can make an utility to modify the schedule by my own. its maybe a file that i can modify, or i saved in the registry?
