Old 02-23-2007, 07:48 AM
PhillJones PhillJones is offline
Remove padding on back to back favorites
I'm using V5.
I put a minute padding on all my shows just in case but if there's a show at 9PM and another at 10PM on different channels sage perceives it as a conflict.
Anybody else see this/have fixed this?
Old 02-23-2007, 10:10 AM
That is normal the remove padding on back to back favorites is if they are on the SAME channel not different ones. That is why I got multiple tuners so that I could eliminate conflicts. Another request I had was to have the padding be there when recording on the same channel. The driver would just output two files at the same time for the overlap. But after asking for this I found out that it was a driver limitation and not a sage one. This also made me want to get additional tuners - currently at 5 (or 6 if my Hauppage USB-PVR2 is feeling ok). 3 analog cable and 3 digital.
Old 02-23-2007, 07:08 PM
Thanks. At least that means there's nothing actually wrong.
Managing favorites garyellis SageTV Software 3 10-02-2006 09:27 AM
Recoding ended early when padding added? tmiranda SageTV Software 0 09-10-2006 04:11 PM
Favorites manager doesn't record. Edwin SageTV Software 1 06-14-2006 06:42 AM
remove padding feature not working kny3twalker SageTV Beta Test Software 8 03-31-2004 03:11 PM
Back to Back Favorites issue with Multi-tuners cards carlgar SageTV Software 0 11-26-2003 04:08 PM
