Old 04-26-2009, 03:30 AM
maninblack_30 maninblack_30 is offline
Feature request: warn before delete if file was Back-to Back
Would it be possible for a pop-up warning to let us know if we are deleting a file that had it's padding removed because it was a back-to-back recording?
Does that make sense?
I have had files delete themselves as I'd watched them, only to find out later they either contained the end or begining of another favorite on them!
It's worse if it contained the end!!!
Fraser
Server:HP DL380 Dual Quad Xeon E5530 2.4Ghz per core, 64GB RAM, 2x Hauppauge HVR-2200 tuners (4 total) 146GB mirrored system drive running Server 2012 R2, 3TB storage HDD space (7x500Gb),
Clients:1 STX HD-100, 1 HD-200, 1 HD-300 for main TV room connected to Pioneer SC-LX72 with Tannoy MX4 mains, MX3 rears and MXm centre (or center!) and Yamaha YST-SW160 subwoofer, Bravia 55' LCD
Old 04-26-2009, 11:43 AM
GKusnick's Avatar
GKusnick GKusnick is offline
I think a better solution to that problem would be general-purpose trashcan/undelete mechanism that would let you retrieve a file that was mistakenly deleted for whatever reason.
-- Greg
Old 04-26-2009, 04:34 PM
reggie14 reggie14 is offline
I've been warming to the idea of a trash can for deleted shows. I think it's possible to come up with a hack that would add the trash can to Sage via a plugin, but it seems like it would be pretty easy to add to the core. Basically it would just piggy back off the current auto-delete mechanism by moving semi-deleted video files to the top of the auto-delete queue, and changing the UI a bit so the main recordings screen doesn't show deleted files and adding a trash can screen.
Old 04-28-2009, 08:29 AM
bshiek bshiek is offline
I am interested in a way to undelete recordings.
Feature Request: More configuration to the Auto-Delete feature jbarr SageTV Software 21 06-19-2007 03:56 PM
Remove padding on back to back recordings on a per favorite basis? Deadbolt SageTV Software 1 04-01-2006 05:28 PM
Went back to 3.0.11 because of view/delete menu changes... Steve2112 SageTV Beta Test Software 25 10-25-2005 06:17 PM
Back-to-Back Padding Removal & Multiple Tuners NikDFish SageTV Software 1 07-04-2005 10:03 AM
Back to Back Favorites issue with Multi-tuners cards carlgar SageTV Software 0 11-26-2003 04:08 PM
