Old 08-17-2011, 12:58 PM
gweedow gweedow is offline
Please need Qam guide for west PA. armstrong
Hello all, I live in Western Pennsylvania.
3 years ago I bought a Samsung flat screen. Was lucky it had all so in it a Qam tuner. Checked the Qam channels out for a while then hooked up the Armstrong cable box and did not brother with Qam anymore.
Now I bought a smaller tv for the kitchen that has a Qam tuner and have tv just hooked up to the cable no box. So I like watching some Qam channels again.
The way I found out about Qam signals is some how I was searching Google 3 years ago and Found a Qam channel guide From Meadville. So I started checking out my Qam. Of course the channels are not the same as My Armstrong who is out Of Connellsville Pennsylvania and a Sub station from California Pennsylvania.
So, Is there anyone here that has an updated Qam guide for Armstrong of Connellsville Pa. or California pa.?? Thanks all.
Old 08-17-2011, 03:14 PM
Go to the SiliconDust webpage Support and use their Channels tool.
Old 08-17-2011, 03:18 PM
panteragstk's Avatar
if you are using a tv all you have to do is make sure the tv supports qam and then scan for digital channels. That's it.
Anyone going to Photonics West? MeInMaui The SageTV Community 1 01-09-2010 01:56 PM
STV Import: Alternative Program Guide & Mini Guide for Default STV wado1971 SageTV Customizations 24 09-13-2009 01:32 PM
Any way to make it so if you press Guide button twice it closes open guide? vorius SageTV Software 9 09-08-2006 12:27 PM
Setting the Default Guide in a Multi-Guide Configuration kkoz SageTV Software 1 12-29-2005 10:28 PM
Zap2it & Shaw digital (west) lineup (Winnipeg) CarlG SageTV Canada 2 12-19-2004 10:02 PM
