Old 01-21-2013, 01:45 AM
frostykev frostykev is offline
HD200 No Video, Sage plays fine
Sage videos play on my main computer just fine, but on the HD200 they won't launch. Well, they launch but then just sit there, no audio, no video, shows status bar like it is playing but only goes to about 6 seconds then nada. First six seconds of all video is blank and no audio.
No recent upgrades or changes. Sage is on V6 I believe (can we still upgrade it to 7?)
Only other oddity, I've noticed the main computer is shutting sage down at various intervals. I only mention this in case it has something to do with the HD200.
Old 01-21-2013, 09:21 AM
Additional note, the HD200 isn't playing videos in stand alone mode either. Any hard reset possible?
Old 01-21-2013, 11:10 AM
KryptoNyte's Avatar
Yes, the free upgrade from V6 to V7 is provided here;
http://forums.sagetv.com/forums/showthread.php?t=56225
It might be wise to at least try and get the HD200 going again prior to the upgrade, just to take one issue at a time.
This post has the very latest firmware for the HD200 in the event you would need to update it in any of the processes below;
http://forums.sagetv.com/forums/show...1&postcount=48
This post has links to the HD200 manual where it [the manual] explains the configuration reset procedure;
http://forums.sagetv.com/forums/show...237#post323237
Old 02-01-2013, 07:46 PM
Thanks! The reset did the trick. I appreciate the links.
hd200
HD200 always plays video matterw SageTV Beta Test Software 3 07-01-2010 09:43 AM
SageTV Stutters on x.264 / Plays fine in WMP Classic RickWakeman SageTV Software 20 09-11-2009 09:13 AM
SD plays just fine HD doesnt recoil SageTV Software 3 07-24-2009 05:17 PM
Audio out of sync in Sage, but plays fine in Media MVP DWeade SageTV Software 3 05-28-2008 10:40 AM
Need help: movie plays fine on server but not on HD100 t4uecker SageTV Media Extender 0 05-26-2008 10:21 PM
