Old 06-24-2004, 10:41 PM
beautye350 beautye350 is offline
Anyone seen this corruption before?
Anyone know why this displays and if there is a fix? Its not a huge deal, mainly aesthetic.
Regards,
Beau
Old 06-24-2004, 10:42 PM
And another.
Old 06-30-2004, 10:55 PM
codecasting codecasting is offline
Yep, I've seen some similar things where part of the GUI doesn't seem to properly clear before another part of it draws. It's been a pretty rare occurance, but you're not alone in seeing it...
Old 07-01-2004, 05:44 AM
nethawk nethawk is offline
I concur. It most likely happened because you resized the screen right?
Old 07-01-2004, 10:14 AM
Um...Yes and No. I did resize my screen, but not right before I did the screen capture.
I notice it a lot when I am clicking the fast forward button to get around watching commercials. At first I was worried, but when I click play again it goes away and the video continues un-corrupted.
Regards,
Beau
Old 07-01-2004, 10:25 AM
My pc launches Sage full screen at startup, so I haven't noticed it tied directly to resizing, either. The "ghost" ui elements seem to disappear after an additional command to update the screen in some way gets issued, so it's a somwhat minor annoyance, but one worth noting.
Old 07-01-2004, 10:46 AM
falchulk falchulk is offline
Are you using mlbdudes stv? It looks like the normal info is being displayed then overlayed by the larger version from a custom stv.
Old 07-01-2004, 11:00 AM
I actually WAS using the mlbdude stv for awhile, but switched back to the original one due to a number of problems I was having with it. Come to think of it, I'm not sure I've seen that issue since switching back, so that may have been the source. Good call!
Old 07-01-2004, 11:05 AM
If you were switching STVs, there is an option to switch "on the fly" in Detailed Setup, but it is 'safer' to exit & restart after switching to make sure everything in the STV is loaded properly.
Old 07-01-2004, 11:06 AM
I've noticed 'ghosting' happens a lot for me with Server but not Client. Client has it's own issues with ghosting, but stuff like menu changes cause my server to have fits.
