Old 07-07-2016, 04:32 AM
Which plugins should we include as core plugins, if we were to auto-install plugins?
The more I think about this, the more I think that we don't really need to auto-install any plugins, but maybe what we need is to create some pseudo plugins that simply auto-installs plugins that "most" people would use when setting up a sagetv server for the first time. In linux (Ubuntu) their package manager has the concept of "layers", which is just a plugin that simply depends on a bunch of other plugins, so when you install it, you get a bunch of plugins without having to manually go and find each one separately. I think that we should use the plugin system and do this for SageTV.
So the question is what are the layers that we should have... and which plugins should be included into those layers.
Here's my take...
AAL01 - Base Layer
- sagex/sagex-services
- SageTV Web UI
- SageTV Mobile UI
- Comksip with Comskip UI
- youtube plugin
- upnp plugin
AAL02 - Fanart Layer
- Base Layer
- BMT Web UI
- phoenix-api/phoenix-core
- CMT (complimentary metadata tools)
- Fanart plugin for default STV (forget the actual plugin name, but I'm sure there is one)
AAL03 - Gemstone Layer
- Fanart Layer
- Gemstone UI
AAL04 - Phoenix Layer
- Fanart Layer
- Phoenix UI (Phoenix 3?)
BTW, the naming of AAL## is just to ensure that these plugins would be listed at the top
The goal here would be that after sagetv server is installed, you can easily go into the plugins and go to the UI section, and select which "layer" to install, and it will then pull in all the other required plugins.
We could still have a mechanisn to auto-install plugins on startup, but, I thinking this is more flexible, and it allows for a clean install, and then users can easily just pick a layer.
The default STV configuration wizzard could be modified to ask the user which "Layer" they want to install, with the option of "none" as well.
So the more I think about it, I think this is just a set of plugins that a defined as layers, and the the default STV, during configuration, just asks the user what they want to install. Nothing really needs to change on the core server code.
Old 07-07-2016, 05:34 AM
SageWizdom SageWizdom is offline
This is a great thought. Is the idea that AAL3 would auto install all the below layers?
Server: Centos Server 14.04 LTS - 64Bit, VM in XenServer, 2 cores of a Intel i7, 2-4 GB Ram, 8 GB system Disk, 1.8 TB storage, SageTV V9.0.4.232, HDHR Prime x 1
Clients: PC Client x 1, HD-300 x 1, AppleTV x 2, WebClient (phone/tablet) x 3
Old 07-07-2016, 06:03 AM
jusjoken jusjoken is offline
I like the concept. It basically can be utilized Out of the Box as you can write a plugin right now that just lists dependencies and will then cause SageTV to install those dependencies as well as their dependencies and so on just by installing this new Layer plugin.
With a few creative developers doing a small portion this could be taken a step further....
  • update the core with a new plugin type called "Layer" or "Package"
  • update the core STV file to support this new type as a new tab in the Plugin Manager so these are all shown together and not dependent on naming
  • update the core STV so the install wizard lists these new "Layers" or "Packages" as an option to install at the end of the wizard.
It may also not be too big a stretch to provide a function in the plugin manager to "Save" your current installed plugin list as a new local "Layer" or "Package" and put it in a file called "SageTVPluginsMyPlugins.xml" and then update the core to recognize this file similar to the "SageTVPluginsDev.xml" file which would then list this "MyPlugins" in the plugin manager for easy install of your complete list of plugins. You could copy this file elsewhere for future installs too.
k
Old 07-07-2016, 07:36 AM
tmiranda's Avatar
tmiranda tmiranda is offline
I love the idea. I'd add the Schedules Direct plugin to the base as a PVR without guide data is not very useful.
If nobody else steps up to "own" the SD plugin I'll consider taking on that role.
Old 07-07-2016, 07:59 AM
I think there would be an issue with auto-installing the SD plugin at this time. I think it ends up disabling the built-in EPG. That, and we really need to make a UI MOD plugin for it to move the configuration INTO the UI instead of dependent on the web UI.
Old 07-07-2016, 08:16 AM
tmiranda's Avatar
I didn't realize that, seems this will need more thought. My goal would be to make it very easy and as automatic as possible. Maybe on the first launch we can check to see if there is a key installed and if not give the user the option to enter one, or install the SD plugin?
We need to make Sage easy for the first time user. Most first timers will not want to end up searching the forums to get it up and running.
Old 07-07-2016, 08:25 AM
In my examples, yes... the AAL3 depends on AAL2 and the plugin manages knows how to resolve dependencies. Again, I only used AAL1, AAL2, etc, for sorting reasons.
k
I agree... have a "Layer" type would be ideal to separate them out. That would probably be a small change to the core. My original thought was to do something that didn't really require any core changes (except for stv), but your idea is better (just more work)
Maybe the EPG configuration could be a separate part of the "configuration wizzard"? We could ask if they want to use SD (maybe only if they haven't configured an API key), and if so, then install the SD plugin.. This could be before asking the user what layer they want to install.
Old 07-07-2016, 08:51 AM
Tiki's Avatar
Tiki Tiki is offline
Since these "layer" packages consist of plugins written by different authors (who may not use or test with all the other plugins), how do you ensure compatibility with revision changes?
For example, maybe the YouTube plugin was written by an author who only uses and tests with the default Sage7 UI, but it happens to work OK with Gemstone too. So, some other person comes along and creates this "layer" package that includes both the YouTube plugin and Gemstone.
But, then later, imagine that the YouTube plugin gets updated in a way that breaks compatibility with Gemstone.
So, how do you make sure that the "layer" package uses the latest versions of all the underlying plugins, but only if they are compatible?
,USBUIRT (multi-zone)
Source:
Comcast/Xfinity X1 Cable
HDHR, HVR-2250, HD-PVR
Old 07-07-2016, 09:05 AM
I'm wondering if it makes sense to look at moving more (all?) of the configuration things to the Web UI. Some things you can only configure in the Web UI, others only in the Sage UI, and some a mixture. It would be kind of nice if there was one configuration location for things and you wouldn't have to worry about possibly adding menu items for it e.g. a Gemstone user adding a new plugin that has a menu item under "Settings".
Old 07-07-2016, 09:07 AM
If you go to the layer package will that mean that I have to install every plugin that is in the package even those I do not use? I lke to keep my SageTV install as light a possible.
AAL01 - Base Layer
- SageTV Web UI
- SageTV Mobile UI
- youtube plugin
- upnp plugin
For example I do not use these.... As most android devices have Youtube which is much better.
- youtube plugin
- upnp plugin
Old 07-07-2016, 10:01 AM
jamesdisco's Avatar
jamesdisco jamesdisco is offline
Definitely need the SD plugin for us international users, i still can't recommend anyone in the UK to use sage as its way too complex getting UK guide data into sage. If all they had to do was sign up to SD then it becomes much easier to access for the non-techie. You'd probably also want to integrate this plugin too for satellite users. It would stop channels from suddenly stopping working with the dreaded 'No Signal'
Server: Win 10 64bit Core i3 8GB 20TB, TBS6985, TBS6984, Sage 9.
Clients: 5 x HD300, 2 x HD200, Placeshifter.
Old 07-07-2016, 10:03 AM
I can't think of anything BUT the schedules direct that you need to configure in the Web UI. Really, the only reason the SD plugin is done there is because Slugger didn't do STV development. It shouldn't be hard to add a configuration screen for the SDEPG plugin to the UI - just someone needs to do so.
More importantly, Sage needs to be able to have the SDEPG installed and be able to choose between them in the UI. Again, shouldn't be difficult, just the UI doesn't currently support it.
Old 07-07-2016, 10:06 AM
Even if you have a key, there are reasons to use SD. Many Non-US/Canada markets, for instance, are supported in the SDEPG, but not in the Core service. I really think that since the SDEPG is only going to be more and more critical, that it needs to become part of the core, and be a selectable option in the wizard - like TVTV was before - and not an added on plugin. It may not actually be that difficult to do - depends on how much 'selection' logic is in the core already.
Old 07-07-2016, 10:48 AM
Out of the ones I use there are BMT, SageAlert and SJQ, (although someone needs to update the SJQ web interface to accept SageTV > 7.x). So, yeah, Slugger heavy. And I think OpenDCT is moving to web UI configuration.
Old 07-07-2016, 11:28 AM
HelenWeathers's Avatar
I personally feel like the SD EPG shoule be part of the core package and the Sage EPG should be a plugin.
The Sage EPG will only be used by some of us who have license keys and those who do have keys are mostly familiar with plugin installs and properties file edits when needed.
Old 07-07-2016, 11:34 AM
There's no reason for them not to BOTH be in there - and honestly, it would be far more difficult to pull the core EPG out than it would be to add the SDEPG in with it.
Old 07-07-2016, 11:40 AM
Really the SDEPG is the only plugin needed for New Users anything else should be optional. I always put on my "Sagetv for Dummies" hat when dealing with new users and pretend I know nothing about SageTV. The less decisions a user has to make on initial install the better.
Old 07-07-2016, 11:46 AM
Skirge01's Avatar
Skirge01 Skirge01 is offline
While I agree with this, it's a matter of ROI. What does the--apparently somewhat involved--process of pulling out the standard EPG get the project at this point in time? New users? New developers? Easier installation? IMO, the few developers we have don't need to be focusing on things like this. Somewhere down the line, when someone has the free time, maybe doing that will be an effective use of their skills, but not at this early stage of development.
Software: SageTV 7
Old 07-07-2016, 11:49 AM
I guess you misunderstood me I am not talking abut ripping out the EPG. I am talking that SDEPG should be the first plugin that should be concentrated on as all others are optional.
Old 07-07-2016, 12:23 PM
Skirge01's Avatar
Ahh! Gotcha. My mistake. In that case, I agree.
Software: SageTV 7
Is there a way to programmatically install plugins? SageWizdom SageTV Github Development 29 06-20-2016 11:41 AM
Philosophy for core vs plugins wayner SageTV Github Development 48 08-14-2015 01:19 PM
How do plugins get into the list of plugins? michaeldjcox SageTV v7 Customizations 4 06-12-2010 03:05 AM
How/Where to install plugins on the Mac? cnr1089 SageTV Mac Edition 0 04-10-2009 10:40 AM
