Old 08-14-2016, 01:51 PM
Jetty Web Server (status update)
FYI...
I've been working on a new phoenix update... which requires a new sagex api update and bmt update, and that got me into the "jetty update" to see what would be involved in getting the jetty web server to the latest build. (since I'm updating sagex and bmt I'll have to update them again for a new web server)
Currently we are using Jetty 6 and Jetty 9 is very different in terms of configurations, etc. I guess Jetty changed ownership (is now owned by eclipse) so the java packages are completely different. But, all that being said, I was able to create a new jetty 9 plugin.
After starting the server, the current web app doesn't work. So i downloaded it and made the changes to get it working. And then it "almost" worked except the groovy stuff didn't work... after spending 2 days on that... I upgraded to the latest groovy and now it works as well
At this point I have a working Jetty 9 with Java 8 and a working sagetv web app. This is still going to take some time to clean this up, but, at least it all works. I'm not sure who owns the current sagetv web app and the groovy plugins, I'll need to update those when I release a new jetty web server.
I was going to release everything together... ie, sagex, phoenix, bmt, jetty, groovy, web app, etc, but I'm thinking that'll be a never ending project
So, I'll go back to my original plan of updateing sagex and phoenix and bmt, and then work on an updated jetty.
Old 08-14-2016, 03:30 PM
Skirge01's Avatar
Skirge01 Skirge01 is offline
Looks like it might be about time to try getting v9 running again on my system.
Thanks for the tireless work you do on Sage!
Software: SageTV 7
Old 08-14-2016, 10:00 PM
fresnoboy fresnoboy is offline
+1!
Thank you!
Old 08-15-2016, 11:40 AM
dstanley's Avatar
dstanley dstanley is offline
Sean,
Thanks for all you do for the SageTV community - I really appreciate all your work!
Dwight
Old 08-15-2016, 02:21 PM
Taddeusz Taddeusz is offline
I installed the sagex v9 update on my Windows system and now I'm getting the following message whenever a sagex query is done:
HTTP ERROR 500
Problem accessing /sagex/api. Reason:
    Sage Servlet Failed: null
Powered by Jetty://
It seems to be working fine on my unRAID test system though.
Old 08-15-2016, 03:04 PM
HTTP ERROR 500
Powered by Jetty://
Could you look in the sagetv_0.txt log file and see if there are any errors? I just tried it on my unRAID setup and my test dev server and it works there... Could be a Java 8 thing... ie, I use Java 8 for development, but I tell the compiler to compile down to Java 1.7... so I think it should still work with Java 1.7.
Old 08-15-2016, 03:44 PM
EnterNoEscape's Avatar
I'm running Java 1.7 on my Windows 7 x64 server and I'm seeing the same error and one other unexpected one.
Here's 1 unsuccessful, 2 successful and the results:
/sagex/api?c=IsDoingLibraryImportScan
This one doesn't accept any parameters.
<error sagex-version="9.0.0">
<message>
<![CDATA[
Too few args; Your Arg Count: 0; Required Arg Count: 1
</message>
<exception>
<![CDATA[
java.lang.RuntimeException: Too few args; Your Arg Count: 0; Required Arg Count: 1
 at sagex.remote.xmlrpc.RequestHelper.createParameters(RequestHelper.java:28)
 at sagex.remote.xmlrpc.RequestHelper.createRequest(RequestHelper.java:19)
 at sagex.remote.factory.request.GlobalFactory.createRequest(GlobalFactory.java:480)
 at sagex.remote.factory.request.SageRPCRequestFactory.createRequest(SageRPCRequestFactory.java:1298)
 at sagex.remote.api.ApiHandler.callSageAPI(ApiHandler.java:208)
 at sagex.remote.api.ApiHandler.handleRequest(ApiHandler.java:150)
 at sagex.remote.SagexServlet.doPost(SagexServlet.java:87)
 at sagex.remote.SagexServlet.doGet(SagexServlet.java:41)
 at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
 at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
 at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:502)
 at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:389)
 at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
 at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:765)
 at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:230)
 at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
 at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
 at org.mortbay.jetty.handler.rewrite.RewriteHandler.handle(RewriteHandler.java:230)
 at org.mortbay.jetty.Server.handle(Server.java:326)
 at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:534)
 at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:864)
 at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:539)
 at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:212)
 at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:404)
 at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:409)
 at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThreadPool.java:520)
</exception>
</error>
/sagex/api?c=RunLibraryImportScan&1=false
It also did successfully kick off a library import.
<Result/>
/sagex/api?c=SageCommand&1=Up&context=0023a500070e
It moved the the cursor up on the extender.
<Result/>
It seems that the issues are with methods that return values. I strangely see nothing in the logs.
Update: I take that back, I saw the following after running /sagex/api?c=GetMediaFiles&1=T:
Mon 8/15 17:47:20.622 [9540670@qtp-30512421-6@91943e] Calling: Api: Mon 8/15 17:47:20.622 [9540670@qtp-30512421-6@91943e] nullMon 8/15 17:47:20.622 [9540670@qtp-30512421-6@91943e] ; Command: Mon 8/15 17:47:20.622 [9540670@qtp-30512421-6@91943e] GetMediaFilesMon 8/15 17:47:20.622 [9540670@qtp-30512421-6@91943e] ;
Old 08-15-2016, 04:19 PM
<message>
<![CDATA[
</message>
<exception>
<![CDATA[
</exception>
</error>
<Result/>
<Result/>
Thanks... I found the issue... I "cleaned up" the generator (a little) in v9 and I introduced a bug I've created a unit test around it now.
I'll try to generate and publish a new build tonight.
Old 08-15-2016, 04:43 PM
HTTP ERROR 500
Powered by Jetty://
It would appear that until you access the web server (ie, the /sage/ or /bmt/) paths, the /sagex path is not activated.
FYI... updated sagex apis to 9.0.0.1 to fix the previous issue.
Old 08-15-2016, 05:19 PM
Thanks for maintaining this incredibly useful API!
Old 08-15-2016, 07:06 PM
I think skiingwiz took over the web app from Slugger. I am not sure if anyone took over the groovy stuff.
Old 08-15-2016, 08:41 PM
KryptoNyte's Avatar
Thank you for doing this work, Sean.
Old 08-15-2016, 08:43 PM
I am seeing exactly the same problem, running 9.0.0.1. I still get this error after accessing BMT or Sage's normal webserver pages (both of those work fine too).
I am running the latest java 8 under linux.
Mike
Old 08-16-2016, 05:07 AM
Mike
I didn't change anything in terms of when/how sagex/api is activated... I just noticed that after I restarted my server, and then hit /sages/api I got the 404 error page. I then hit /sage/ and then went back to /sagex/api and then it worked.... it could have been a timing thing on my part (ie, the web server was not fully started when I first hit it). This update for the sagex-api to v9 is just a jar file change that adds/updates apis that have changed since v7.
But, if you are still having the issue, then check the sagetv_0.txt logs and see if there is an issue there.
Old 08-16-2016, 07:55 AM
I upgraded to 9.0.0.1 this morning and I'm still getting this error on my Windows server. I don't see an error in the log. I'm seeing this entry:
Tue 8/16 8:52:59.379 [5625690@qtp-5352340-3@55d75a] Calling: Api: Tue 8/16 8:52:59.380 [5625690@qtp-5352340-3@55d75a] nullTue 8/16 8:52:59.380 [5625690@qtp-5352340-3@55d75a] ; Command: Tue 8/16 8:52:59.380 [5625690@qtp-5352340-3@55d75a] GetMediaFilesTue 8/16 8:52:59.380 [5625690@qtp-5352340-3@55d75a] ;
Old 08-16-2016, 08:37 AM
Here's what my sagetv_0.txt says (copied from my ssh window):
Tue 8/16 7:31:09.881 [main@271053e1] Error discovering servers:java.net.SocketTi
meoutException: Receive timed out
Tue 8/16 7:31:10.401 [main@271053e1] detect 3
INFO - Configured Root Logger
Tue 8/16 7:20:36.643 [SageTV@47b6e73] LOG4J: Configured Root Logger
INFO - Configured Logging for: sagex-api using file: sagex-api.log4j.properties
Tue 8/16 7:20:36.692 [SageTV@47b6e73] LOG4J: Configured Logging for: sagex-api u
Tue 8/16 7:20:36.740 [SageTV@47b6e73] ::INFO: Logging to sagex.jetty.log.JettyS
tarterLogger@1d1e09c5 via sagex.jetty.log.JettyStarterLogger
Tue 8/16 7:20:36.740 [SageTV@47b6e73] ::INFO: Jetty Starter plugin version 2.3.
0.14
Tue 8/16 7:20:37.129 [SageTV@47b6e73] ::INFO: Starting Jetty
Tue 8/16 7:20:37.130 [SageTV@47b6e73] ::INFO: Jetty Plugin log level: INFO
Tue 8/16 7:20:37.337 [SageTV@47b6e73] ::INFO: jetty-6.1.19
Tue 8/16 7:20:37.409 [SageTV@47b6e73] ::INFO: Deploy /opt/sagetv/server/jetty/c
ontexts/mediastreaming.xml -> org.mortbay.jetty.webapp.WebAppContext@2b1a6de7{/s
tream,/opt/sagetv/server/jetty/webapps/MediaStreaming.war}
Tue 8/16 7:20:37.426 [SageTV@47b6e73] ::INFO: mime.types file not found in over
ride location /opt/sagetv/server/webserver/mime.types. Checking default locatio
ns.
Tue 8/16 7:20:37.451 [SageTV@47b6e73] ::INFO: Deploy /opt/sagetv/server/jetty/c
ontexts/nielm_websrv.context.xml -> org.mortbay.jetty.webapp.WebAppContext@2d526
e96{/sage,/opt/sagetv/server/jetty/webapps/nielm_sagewebserver.war}
Tue 8/16 7:20:37.459 [SageTV@47b6e73] ::INFO: Deploy /opt/sagetv/server/jetty/c
ontexts/bmt.xml -> org.mortbay.jetty.webapp.WebAppContext@57e85914{/bmt,/opt/sag
etv/server/jetty/webapps/bmt.war}
Tue 8/16 7:20:37.472 [SageTV@47b6e73] ::INFO: Deploy /opt/sagetv/server/jetty/c
ontexts/apps.xml -> org.mortbay.jetty.webapp.WebAppContext@7a114eb9{/apps,/opt/s
agetv/server/jetty/webapps/apps.war}
Tue 8/16 7:20:37.533 [SageTV@47b6e73] Media Servlet Handler Created.
Tue 8/16 7:20:37.540 [SageTV@47b6e73] Sagex ApiServlet Created for version: 9.0.
0
Tue 8/16 7:20:37.656 [SageTV@47b6e73] SAGEX-API: Starting Http Context
Tue 8/16 7:20:37.657 [SageTV@47b6e73] SAGEX-API: Updated Constrant Authenticatio
n: true
Tue 8/16 7:20:37.657 [SageTV@47b6e73] ::INFO: Deploy /opt/sagetv/server/jetty/c
ontexts/sagex.xml -> org.mortbay.jetty.servlet.Context@37be0d29{/sagex,null}
Tue 8/16 7:20:37.676 [SageTV@47b6e73] ::INFO: Deploy /opt/sagetv/server/jetty/c
ontexts/sagewebapp.xml -> org.mortbay.jetty.webapp.WebAppContext@7c744411{/sagem
,/opt/sagetv/server/jetty/webapps/SageWebApp.war}
Tue 8/16 7:20:37.759 [SageTV@47b6e73] ::INFO: Extract /opt/sagetv/server/jetty/
webapps/MediaStreaming.war to /opt/sagetv/server/jetty/webapps/MediaStreaming/we
bapp
Tue 8/16 7:20:38.360 [SageTV@47b6e73] ::INFO: SegmenterProcess transcoder for H
TTPLS web streaming is /opt/sagetv/server/ffmpeg
Tue 8/16 7:20:38.360 [SageTV@47b6e73] ::INFO: SegmenterProcess segmenter for HT
TPLS web streaming is /opt/sagetv/server/jetty/webapps/MediaStreaming/webapp/WEB
-INF/bin/linux32/ffmpeg
Tue 8/16 7:20:38.456 [SageTV@47b6e73] ::INFO: Extract /opt/sagetv/server/jetty/
webapps/nielm_sagewebserver.war to /opt/sagetv/server/jetty/webapps/nielm_sagewe
bserver/webapp
Tue 8/16 7:20:38.602 [SageTV@47b6e73] ::INFO: Extract /opt/sagetv/server/jetty/
webapps/bmt.war to /tmp/Jetty_0_0_0_0_8080_bmt.war__bmt__9xmt47/webapp
Tue 8/16 7:20:39.083 [SageTV@47b6e73] ::INFO: Extract /opt/sagetv/server/jetty/
webapps/apps.war to /opt/sagetv/server/jetty/webapps/apps/webapp
Tue 8/16 7:20:39.216 [SageTV@47b6e73] ::INFO: Extract /opt/sagetv/server/jetty/
webapps/SageWebApp.war to /opt/sagetv/server/jetty/webapps/SageWebApp/webapp
Tue 8/16 7:20:39.507 [SageTV@47b6e73] ::INFO: Opened /opt/sagetv/server/jetty/l
ogs/2016_08_16.request.log
Tue 8/16 7:20:39.516 [SageTV@47b6e73] ::INFO: Started SelectChannelConnector@0.
0.0.0:8080
INFO - Configured Logging for: phoenix using file: phoenix.log4j.properties
Tue 8/16 7:20:39.536 [SageTV@47b6e73] LOG4J: Configured Logging for: phoenix usi
INFO - Configured Logging for: phoenix-metadata using file: phoenix-metadata.log
4j.properties
Tue 8/16 7:20:39.536 [SageTV@47b6e73] LOG4J: Configured Logging for: phoenix-met
adata using file: phoenix-metadata.log4j.properties
Aug 16, 2016 7:20:39 AM org.fourthline.cling.UpnpServiceImpl <init>
INFO: >>> Starting UPnP service...
INFO: Using configuration: org.fourthline.cling.DefaultUpnpServiceConfiguration
Aug 16, 2016 7:20:39 AM org.fourthline.cling.transport.RouterImpl <init>
INFO: Creating Router: org.fourthline.cling.transport.RouterImpl
Aug 16, 2016 7:20:39 AM org.fourthline.cling.transport.impl.MulticastReceiverImp
l init
INFO: Creating wildcard socket (for receiving multicast datagrams) on port: 1900
l init
INFO: Joining multicast group: /239.255.255.250:1900 on network interface: eth0
Aug 16, 2016 7:20:39 AM org.fourthline.cling.transport.impl.StreamServerImpl ini
t
INFO: Created server (for receiving TCP streams) on: /10.0.8.130:46198
Aug 16, 2016 7:20:39 AM org.fourthline.cling.transport.impl.DatagramIOImpl init
INFO: Creating bound socket (for datagram input/output) on: /10.0.8.130
INFO: <<< UPnP service started successfully
Tue 8/16 7:20:41.164 [SageTV@47b6e73] SLF4J: Failed to load class "org.slf4j.imp
l.StaticLoggerBinder".
Tue 8/16 7:20:41.164 [SageTV@47b6e73] SLF4J: Defaulting to no-operation (NOP) lo
gger implementation
Tue 8/16 7:20:41.164 [SageTV@47b6e73] SLF4J: See http://www.slf4j.org/codes.html
#StaticLoggerBinder for further details.
Aug 16, 2016 7:20:54 AM org.fourthline.cling.binding.xml.UDA10DeviceDescriptorBi
nderImpl hydrateSpecVersion
WARNING: Unsupported UDA minor version, ignoring: 1
Tue 8/16 7:21:07.212 [EPG@63534aeb] MaintenceMetric(MediaMaskUpdateShow): 105ms
for 0 items in 1 loops, lock time 0 ms
Tue 8/16 7:21:07.276 [EPG@63534aeb] MaintenceMetric(MediaMaskUpdateTitle): 1ms f
or 12 items in 1 loops
Tue 8/16 7:21:07.333 [EPG@63534aeb] MaintenceMetric(MediaMaskUpdateYears): 0ms f
or 1 items in 1 loops
Tue 8/16 7:21:07.436 [EPG@63534aeb] MaintenceMetric(MediaMaskUpdatePeoples): 5ms
for 58 items in 1 loops
Tue 8/16 7:21:07.497 [EPG@63534aeb] MaintenceMetric(MediaMaskUpdateCategories):
0ms for 0 items in 1 loops
Tue 8/16 7:21:07.564 [EPG@63534aeb] MaintenceMetric(MediaMaskUpdateSubCategories
): 0ms for 0 items in 1 loops
Tue 8/16 7:21:07.624 [EPG@63534aeb] MaintenceMetric(MediaMaskUpdateRated): 0ms f
Tue 8/16 7:21:07.684 [EPG@63534aeb] MaintenceMetric(MediaMaskUpdatePRs): 0ms for
0 items in 1 loops
Tue 8/16 7:21:07.744 [EPG@63534aeb] MaintenceMetric(MediaMaskUpdateERs): 0ms for
0 items in 1 loops
Tue 8/16 7:21:07.805 [EPG@63534aeb] MaintenceMetric(MediaMaskUpdateBonus): 0ms f
INFO - Configured Logging for: bmtweb using file: bmtweb.log4j.properties
Tue 8/16 7:24:39.108 [877171180@qtp-284912954-5@344891ec] LOG4J: Configured Logg
Old 08-16-2016, 08:47 AM
and here is the sagex-api log file:
2016-08-16 07:31:43,060 [1382164443@qtp-284912954-7] WARN sagex.remote.SagexServlet - Failed to process Sage Handler!
java.lang.StackOverflowError
at java.util.regex.Pattern$CharProperty.match(Pattern.java:3776)
at java.util.regex.Pattern$Curly.match(Pattern.java:4227)
at java.util.regex.Pattern$Start.match(Pattern.java:3461)
at java.util.regex.Matcher.search(Matcher.java:1248)
at java.util.regex.Matcher.find(Matcher.java:637)
at java.util.regex.Matcher.replaceAll(Matcher.java:951)
at java.lang.String.replaceAll(String.java:2223)
at sagex.remote.builder.SageAPIBuilder.makeName(SageAPIBuilder.java:237)
at sagex.remote.builder.SageAPIBuilder.buildSimpleData(SageAPIBuilder.java:84)
at sagex.remote.builder.SageAPIBuilder.build(SageAPIBuilder.java:33)
at sagex.remote.builder.SageAPIBuilder.buildObject(SageAPIBuilder.java:156)
at sagex.remote.builder.SageAPIBuilder.buildChannel(SageAPIBuilder.java:100)
at sagex.remote.builder.SageAPIBuilder.build(SageAPIBuilder.java:63)
at sagex.remote.builder.SageAPIBuilder.buildAiring(SageAPIBuilder.java:120)
at sagex.remote.builder.SageAPIBuilder.build(SageAPIBuilder.java:57)
this last set of lines just keeps on repeating - probably because my plex server is doing a query for all the recordings as part of the plex plugin running.
thx,
mike
Old 08-16-2016, 09:03 AM
thx,
mike
I see the same thing and for the time being until this can be resolved I don't have my Plex running.
Old 08-16-2016, 09:25 AM
So when you got to /sagex/api without any parameters... do you get an error?
Old 08-16-2016, 09:46 AM
Nope. Returns the list of possible parameters, etc...
Thx
Mike
Plugin: Jetty Web Server 2.0 jreichen SageTV v7 Customizations 389 06-19-2021 09:38 PM
Jetty Web Server Issue Ghildebr SageTV v9 Customizations 17 09-03-2016 09:52 AM
Windows OS Update For Server? voorhees General Discussion 11 12-28-2012 03:26 PM
