Old 06-12-2017, 08:08 AM
ranger ranger is offline
TV Editorials Cleanup / SDEPG
I migrated all my tuners to SD EPG about 2 weeks ago and all that is working, however the TV Shows Editorials screen is still showing editorials from the last time I updated the (now) legacy EPG. Most recent dated item is from June 11th so nothing new is populating.
I know the Editorials work differently under SD, but is there any way to clean out the old editorials?
edit - BTW, I am running V9.1.2.662
Old 06-12-2017, 08:14 AM
EnterNoEscape's Avatar
I do not know of a way to purge them manually. They will clear out slowly on their own.
Old 06-12-2017, 02:02 PM
Tiki's Avatar
Tiki Tiki is offline
ENE had talked about a replacement for the Editorials screen in a previous post, but I don't think it has been implemented yet. The SD EPG data doesn't include the information used to generate the Editorials screen, but he was going to do something that created a list of suggested upcoming shows based on your viewing history (sounded kind of like the Intelligent Suggestions plugin to me).
So for now I think the Editorials screen is just kind of useless if you are getting EPG data from Schedules Direct.
,USBUIRT (multi-zone)
Source:
Comcast/Xfinity X1 Cable
HDHR, HVR-2250, HD-PVR
Old 06-12-2017, 02:08 PM
In the latest versions of SageTV, it should be populating with something unless it can't find any suggestions from Schedules Direct that you don't already have a favorite for. It does make a small effort to not suggest things that you already have a clear interest in watching. I can't guarantee that it will actually show something for everyone because it's largely dependent on if the programs being looked up have suggestions.
TV Show Editorials trallyus SageTV EPG Service 18 06-21-2017 05:57 PM
SDEPG Download fails mikeg SageTV EPG Service 6 05-25-2017 08:42 PM
new Linux setup - problem with sdepg and BMT jt4242 SageTV Linux 5 03-07-2017 06:28 PM
Restrict TV Show Editorials channels? drewg SageTV Software 0 09-22-2010 07:20 AM
TV Editorials not updating Sean977 SageTV Beta Test Software 7 12-07-2007 08:43 AM
