Old 11-05-2005, 06:13 AM
robd robd is offline
Is anyone using tvtv with v4 in the UK yet?
I'm thinking of upgrading to v4 and maybe using tvtv for EPG.
Just wondered if anyone had already taken the plunge (tvtv that is)?
The main concern that I have is channel numbering.
I'm on Telewest so I guess the question is does anyone know if tvtv provides compatible channel numbers?
Yes, I know they can be changed manually but it's a much better (more integrated) solution if tvtv can do that for me ...
If anyone wants to share their experiences of v4 and/or tvtv in the Uk it would be much apprecieted
Old 11-07-2005, 09:36 AM
danward79's Avatar
danward79 danward79 is offline
I was just about to post the same question, has anyone done this yet?
Old 11-08-2005, 02:59 AM
nielm's Avatar
nielm nielm is offline
TVTV does not have provider-based channel numbering -- remapping will always have to be done manually.
Last time I checked (2 weeks ago) TVTV was missing some channels and some data, and finally, the 60 channel limit can be a bit restrictive for some providers...
Old 11-08-2005, 04:30 AM
danward79's Avatar
Thanks for tha answer
Old 11-08-2005, 05:03 AM
Yep ... thanks ...
I might upgrade this weekend and see if v4 and tvtv is any better than my current XMLTV (Radio Times) setup and post the results here ...
