Old 12-20-2005, 12:19 PM
potpiejimmy's Avatar
potpiejimmy potpiejimmy is offline
Angry TVTV and 2 sources ... impossible??
Hi,
I'm trying to use my TVTV account for TWO different sources. Everytime I add a new source and configure it to use TVTV, any other previously configured source that uses TVTV is silently removed from the video sources list. Only the last source that has been added appears in the list, the other sources are just gone
I am using a Hauppauge PVR-350 with both the composite input and the card's tuner as a video source. It works great if I use my XMLTV setup for the Tuner input and TVTV for the Composite input, but I can't have two video sources using TVTV. Is this an intended behavior (I don't think so)? Is it at all possible to use TVTV with two different video sources??
Old 12-20-2005, 12:23 PM
LostInSpace LostInSpace is offline
The TVTV settings are use for all sources configured with TVTV.
So it's not possible to use different TVTV accounts for different sources.
But you can use TVTV for one source & XMLTV for another one...
Personnaly, I use TVTV for all my 5 encoders and it's working fine.
Ferdinand
My config:
AMD athlon64 3200+ / 1 GB RAM / MSI K8N Neo4 / ATI X800 PRO / Technotrend Budget C-1500 / 300GB SATA HD / Win Vista Ultimate
Old 12-20-2005, 12:40 PM
I don't want to use different ACCOUNTS. I want to use the SAME account with two different SOURCES.
So this means it works with different hardware devices, but it doesn't work for two video sources using the same device (as in my case the tuner and the composite input on my pvr-350). Is that right?
Old 12-20-2005, 02:41 PM
Yes, that is the key right there.
You can use multiple inputs on the same source, but when you do so, they have to use different lineups without overlapping channels. (The same capture device can't have the same channel listed for two of its inputs.)
