Old 12-09-2006, 02:33 PM
jsonnabend jsonnabend is offline
EventCodes for pound and star
I looked but can't seem to find event codes for the pound and star keys. Can someone point me in the right direction?
TIA
- Jeff
Old 12-09-2006, 03:01 PM
ke6guj ke6guj is offline
Not sure what you are exactly needing. Are you looking for set up the # and * buttons to do something in Sage, or to actually send a # or * in a sendmessage.
This is what I have this in my irremote.ini
TEXT={findwnd(SageApp,SageWin)}{SendMsg(1258,0,24)}
SUBCC={findwnd(SageApp,SageWin)}{sendMsg(1258,0,27)}
The TEXT line corresponds to the * key on the hauppauge remote and the SUBCC line corresponds to the # key. I have TEXT linked to INFO, and SUBCC linked to full screen/windowed.
I didn't see any info in the Sage manual about any event codes for # and *.
Old 12-09-2006, 06:14 PM
Thanks for the info. I'm trying to send # and * from Girder. I see event codes for Num 0 through Num 9, but not for # and *. Does Sage not use these two keys?
- Jeff
Old 12-09-2006, 07:12 PM
OK, did a little more digging. when Sage updates the irremote.ini for a hauppauge remote, it sets up the following lines:
TEXT={subtract}
SUBCC={ctrl}{shift}c
If * = "-", then it looks like you could use event code 95 if you are trying to use the * to do a ATSC subchannel.
Now, for the #, I dunno what "{ctrl}{shift}c" does so I can't help you on that one. What do you need # for in Sage?
You could always send in a support request to see if there are any event codes that haven't been documented yet.
Old 12-09-2006, 09:49 PM
All commands are listed at the end of chapter 5 in the manual and in Detailed Setup -> Commands -> Link Command (v6 displays the command number for each command).
Old 12-11-2006, 08:56 AM
Ah, ok, I got it. I confused "event codes" with "default keystroke", which happen to be the same for the number pads. Since there's no "#" or "*" default keystroke, it's up to me to map the remote buttons to whatever event codes I want.
Thanks for pointing me to chapter 5, and sorry about the confused question.
- Jeff
