Old 12-18-2007, 10:38 AM
dadams dadams is offline
HD Media Extenter picture freeze
While watching some SD programs my picture freezes, then after 2 minutes or so the extender shuts down (I assume because it can't recover) I tried 3 different shows (all SD captured from pvr-500) and have the same results. They work through the MVP's. I didn't really watch enough HD programs to know if it happens with the high def shows.
My server is a Core 2 Duo 6400 w/ 2Gb memory, 7600GS. I'm running SageTV 6.3.5
I have submitted a support request, but wanted to run it by the forums since I've received a lot of help here in the past.
Old 12-18-2007, 08:46 PM
When you say "picture freezes" I'm assuming you mean that there's video on the screen?
I've got both SD via PVR 500 (2 PVR500's) and HD via HD Homerun recordings. I've never seen video freezing on screen yet.
Question, what recording quality are your PVR 500's set for? Mine are set for "Great" which is 2 gb per hour.
I'm also guessing that you've gotten a successful firmware upgrade on the HD Extender?
What's your recording directory layout? I.e. are the drives local to the server, on another machine, on the network, UNC paths? Mine are right on the server with regular non-UNC paths.
Are you using any STV's/STVi's?
Wayne Dunham
Old 12-18-2007, 09:50 PM
insomniac's Avatar
insomniac insomniac is offline
I have experienced freezing as well. Ive noticed most of the freezes get triggered inbetween programming "mux switch?"
I had my setup at 720p at the time. After switching to 1080i, i have not experienced freezes yet. go figure..
I will update this post if I experience anymore freezing.
EDIT: A day later, and still no freeze issues since switching to 1080i
I.
If you're not cheating, your not trying...
My sage rigs:
Server - Windows 2003, Intel 865 PERLL w/ P4 3.2g 1gb ram, 3-PVR250, 3-PVRUSB's, 1 Skystar2, 1 twinhan 102g, 1 starbox DVB-S Cards. Evo network QAM encoder. 1.2TB storage 6.x server + MTSAGE for DVB
Client 1/Master BR - MediaMVP running a 30" Olevia LCD TV.
Client 2/Front Room - Shuttle ST61G4 XPC 1gig ram, 60gb HD, BTC9019 wireless keyboard/mouse & Harmony 880. 6.x client. GF6600GT driving a Sony WEGA 55" rear projection tv.
Old 12-18-2007, 10:10 PM
yes
yes and yes
local to the server and no to the StV's. The weird thing is that last night it happened all of the time. Tonight, I can't get it to happen. Now I have no idea. Hopefully, the problem won't come back.
HD Media Extender With Vista buceyes SageTV Media Extender 3 11-28-2007 09:24 PM
Congrats on the HD media extender and Sage Server system mikesm General Discussion 288 09-26-2007 08:35 AM
Feature Request - Picture in Picture Mahoney SageTV Software 4 10-04-2006 01:23 PM
SageTV Media Center Software for Windows Now Available for Linux dkardatzke Announcements 0 01-06-2005 09:56 AM
