Old 01-13-2009, 07:21 PM
Kypp Kypp is offline
Playback Video_TS folders on PC
So I have ~200 DVD's backed up to my HTPC that play just fine over my HD200 extender. They are full backups of the entire discs from DVD Shrink in the Video_TS format.
I'd like to be able to play these back on my PC since it is staged in my exercise room and it would be great to be able to play back my DVD collection without the discs while I am burning the miles on the exercise bike. Can anyone let me know how to do this.
Old 01-13-2009, 08:00 PM
S_M_E S_M_E is offline
My Sage Client plays DVDs in the VIDEO_TS folder format on my PC just fine. All you should need is the client, a network connection to the Sage server and the proper decoder for DVD playback on the PC. Most DVD drives come with a decoder like PDVD5 or whatever.
Old 01-13-2009, 08:06 PM
I only have one PC that is the server and serves media to my HD200 in the living room. The server happens to be in my workout room and I'd like to be able to play movies directly from it. If I try and play them in Sage then I get a playback exception error.
Old 01-13-2009, 08:09 PM
You need to use a decoder in Sage that supports playing commercial DVDs. The Sage decoder does not.
Old 01-13-2009, 08:20 PM
Yeah, if you're playing from the server that eliminates the client and the network connection but you still need a decoder.
Old 01-28-2009, 06:40 PM
mikel mikel is offline
Just use this
http://www.videolan.org/vlc/
Works fine. It's small footprint works with almost any audio/video format.
Old 01-30-2009, 04:48 PM
babgvant babgvant is offline
the MPC project includes a filter that just does the decryption (DECSS), you might be able to use that along with the Sage MPEG decoder w/o getting another one.
babgvant.com | @babgvant | Missing Remote
Old 01-30-2009, 06:06 PM
You can also google for Dscaler5. I believe it is still up on Sourceforge and can do commercial DVDs. And it's free.
Old 01-30-2009, 06:15 PM
hingepin hingepin is offline
KMPlayer is another good one. Easy to set up. Cnet reviewed it as one of the best freeware programs out there.
http://www.download.com/The-KMPlayer...tag=mncol;pick
Old 02-08-2009, 06:23 AM
jetradio jetradio is offline
Quick question - did you rip your DVDs to one large file, or did you break them up? I didn't break up my files (using DVD Shrink) and I'm having major playback issues.
STX-HD100 Random Playback Problems with "some" h.264 recordings from HD-PVR shadeblue.com SageTV Media Extender 7 11-03-2008 04:16 PM
Help please! H.264 mpeg4 playback with R5000. cejota3 SageTV Software 9 11-02-2008 04:28 PM
SageTV and import folders bastafidli SageTV Software 0 01-27-2008 12:42 AM
