Old 09-08-2009, 08:13 PM
ErikM ErikM is offline
Strange Behvaior with My Videos
I was wondering if someone could point me in the right direction. Recently, I looked into editing the title of several of my ripped TV episodes and later realized that I wanted to go back to just seeing the filename (which places them in the correct order).
For some unknown reason, the first 14 episodes appear to be lumped together with the previously unique title that I created. I have tried to remove this unique title and have all 14 files appear individually; however, this did not work.
Later, I removed all TV episodes from the parent folder and “Refreshed import media” and the folder disappeared from my video library (as expected); however, any attempt to bring the files back into the folder causes the same behavior.
I need to know what I file I need to delete or edit to allow Sage TV (using SageMC) to properly show these files again.
I am using “File System | Folder View | No Filter” as my default view. Also, this issue does not happen when I am using the native SageTV view (only when I invoke SageMC).
Thank you in advance,
Erik
Software Version: SageTV V6.6.2.218
Java Version: 1.6.0_15
SageMC STV Version: 6.3.9a
Sagemc.jar Version: 6.3.8
Df_sageutils.jar Version: 2.2
Phoenix.jar Version: 1.36
Old 09-09-2009, 06:53 AM
since the title is wrong in SageMC but correct in the default i would look at .my files. .my files are only supported SageMC (whereas BMT, mediascraper (if creating .property files), nielms webserver, etc are all STV agnostic in terms of metadata presented to the user). I've never used .my files but i believe they are stored alongside the recordings (in the same directory).
Check out TVExplorer
Old 09-09-2009, 10:29 AM
Phydeaux Phydeaux is offline
See my post about media tags causing this behavior:
http://forums.sagetv.com/forums/show...509#post369509
I use abcAVI Tag Editor which seems to work well.
RLW
Old 09-13-2009, 07:59 PM
Question
Where would I find these files? I've checked everywhere and cannot find anything...
Old 09-13-2009, 08:01 PM
RLW
I read the thread you referenced and even downloaded a utility; however, these files that I am referring to are not .AVI files, but rather .WMV files.
Any suggestions?
I feel like I need to find a key file that SageMC creates to group these files accordingly. I believe such a file became corrupted or "confused" when I temporarily edited the title and later cleared out the title. For some reason, it has grouped 14 individual .WMV files together. I see only one entry with the unique title and the first .WMV episode plays when I select it. I cannot play the remaining 13 from within SageMC.
Old 09-13-2009, 08:40 PM
if you can't find them in the same directory as the video file then you probably aren't using them.. i would look into phydeaux's suggestion
Cannot play any videos under MY Videos Section info SageMC Custom Interface 1 05-16-2009 05:53 PM
how to move videos from my videos to my tv Lost85 SageMC Custom Interface 5 01-23-2009 05:38 PM
SAGETV wont play videos in MY Videos Jetracers SageMC Custom Interface 2 11-06-2008 07:38 AM
Here's a strange one antplugger SageTV Beta Test Software 2 07-16-2008 04:04 AM
Moving Sage-recorded Videos from Imported Videos to SageTV Recordings esims21 SageTV Software 1 02-05-2005 11:32 AM
