Old 05-09-2015, 09:47 AM
reccitron reccitron is offline
Recordings Missing
All of a sudden a lot of my recordings are missing from the SageTv recording listing. The recorded files are still on the hard drives. Also while I am watching a show, that show isn't showing up in the recorded list like it used to do.
Anyone know what is wrong and how I can fix it?
I did a search and found a post on recreating the wiz.bi but it included an export/import which won't work for me. If I simply delete the wiz.bin will SageTv recreate it with all the shows?
I've restarted the server and service but that hasn't fixed it.
Old 06-07-2015, 11:58 AM
tvmaster2's Avatar
did you ever find the answer to this?
Old 06-08-2015, 10:19 PM
I ended up do a fresh install of windows and Sage
Old 06-09-2015, 12:48 AM
tvmaster2's Avatar
yeah, almost the same here: deleted Wiz.bin and my two tuners, rebuilt the channel lineups, and then rescheduled my favorites. All is now well. must have been a corrupted file somewhere.
Old 06-09-2015, 02:48 AM
bunch92 bunch92 is offline
For me , last time something similar happened was because the recording menu was only showing archived recordings for some reason. I pressed the "Option" button and changed the view to display "All recordings".
Not sure if related to your issue , but something to check next time it happens
Server : Asus M4A79XTD Evo / AMD Phenom II X4 955 @ 3.2GHz / 4Gb RAM / Win 10 64-bit / Cinergy 2400iDT (French Freeview - TNT) / 2 * Hauppauge NOVA-HD-S2 (UK Sky) / TT CT-3650 CI / HDD : 4.5 To / Sage V7 / XMLTV Importer / EPG from WebGrabPlus+/ LM DVB Recorder for all tuners / 2 Clients : STP-HD300
missing, recordings
Missing recordings drewg SageTV Linux 2 03-19-2008 12:06 PM
Help! Missing Recordings Fusion SageTV Software 4 03-06-2008 11:42 AM
Recordings missing jjstok SageTV Software 2 04-02-2007 12:35 PM
Missing Scheduled Recordings Harris_C SageTV Software 1 08-26-2006 12:50 AM
Missing Recordings ewerx SageTV Software 2 11-05-2004 02:21 PM
