Old 10-30-2016, 06:21 AM
current status of Hauppauge WinTV-quadHD pci board
Wondering how this board works with v9 sagetv. I had a 2250 board fail & was looking for a replacement & noticed that quad is only multi-tuner card available now still in production.
Old 10-30-2016, 07:22 AM
read this thread
https://forums.sagetv.com/forums/showthread.php?t=63561
Does it pretty well cover everything up to now?
Old 10-30-2016, 08:53 PM
It works as a 2 tuner card under windows for SageTV.
Nobody has bothered to do the work to get SageTV to use BDA to access the other 2 tuners, so they're vestigal at best.
As the other link explains, the card evidently is supported under Linux Kernel 4.9, but there aren't any major Linux distro's out there currently which use that Kernal. Looks like Ubuntu might support it once they do a 17.10 build release, but that hasn't happened yet.
I don't think anybody has tried the card in a Linux machine running an older distribution to see what the card will do. And obviously, as there's a lack of kernal 4.9 options currently, nobody knows how it'll work under SageTV under Linux in that circumstance either. Just because it "works for Linux" doesn't mean it'll work for SageTV without someone tweaking things first.
Old 10-31-2016, 01:50 AM
I think I'd much rather look to an HDHomeRun than the quadHD board. No driver issues to deal with.
Old 10-31-2016, 07:39 AM
EnterNoEscape's Avatar
I couldn't agree more.
Old 10-31-2016, 10:02 AM
cncb cncb is offline
I think you mean "2" HDHomeRuns. I really wish they would make a 3-tuner version for OTA...
-Craig
Old 10-31-2016, 04:03 PM
Well, the OP was talking about replacing a failed 2250, which is just 2 tuners.
Hauppauge WinTV-quadHD SHS Hardware Support 187 11-14-2020 04:49 PM
WinTV-quadHD Ghildebr Hardware Support 24 01-29-2017 11:19 AM
HD200-Blu Ray Menus-Current Status Linkin_Logs SageTV HD Theater - Media Player 13 12-01-2009 01:02 PM
What is the current status of the Media MVP and sagetv? AJ Bertelson Hardware Support 7 11-27-2009 08:23 PM
Current status of DVB Support in Sage AndersNolberger Hardware Support 10 02-05-2005 11:06 AM
