Old 11-10-2020, 09:17 PM
dotheDVDeed dotheDVDeed is offline
Well HDHomerun is a complete no go
HDHomerun Setup Version 20201030
Windows 7 64
Have tried repeatably. Reinstalled software over and over.
Strictly OTA
Works fine with their HDHomeRun Viewer. In SageTV Channel Setup it sees the tuners but the Channel Scan always turns up no found tunable channels.
The tuner light flashes while it's scanning for channels.
Is there a recommended order of software installation? HDHomerun first?
SageTV first?
At my wits end.
HDHomeRun Setup has BDA Compatibility Mode settings:--Default, Easy HDTV DVR, For the Record, JRiver Media Center, Media Portal, Next PVR, WMC
But no setting for SageTV (Do I vaguely remember a setting here in previous versions?)
Tim
Last edited by dotheDVDeed; 11-10-2020 at 10:01 PM. Reason: Added note about BDA Compatibility Mode
Old 11-10-2020, 10:01 PM
JustFred JustFred is offline
Try the SiliconDust HDHomeRun Setup Instructions at the bottom of the page at: https://sagetv.fandom.com/wiki/Appen...apture_Devices
Added:
If the HDHR Setup program doesn't offer SageTv as an Application in the BDA Compatibility settings:
My tests have shown that Sage works when Application is set to either SageTv, BeyondTV or Other: ATSC/QAM. If none of these seem to work, try restarting the PC.
Last edited by JustFred; 11-10-2020 at 10:10 PM. Reason: Added DBA Compatability info
Old 11-11-2020, 07:55 AM
Tiki's Avatar
Tiki Tiki is offline
You have to have the 32-bit version of Sage installed before you install the HDHR software, otherwise Sage won’t show up as an option.
The HDHR doesn’t recognize 64-bit Sage. It works with 64-bit Sage, but it doesn’t detect that it’s installed, so it doesn’t show you the option to configure for Sage.
,USBUIRT (multi-zone)
Source:
Comcast/Xfinity X1 Cable
HDHR, HVR-2250, HD-PVR
Old 11-11-2020, 10:56 AM
Thank you, thank you, thank you Tiki.
That did the trick. Install the 32 bit version--no setup required. HDHomerun Setup will "sniff" the drive and offer "SageTV" in the BDA Compatibility pulldown window.
Tim
Old 10-03-2021, 05:11 PM
tvmaster2's Avatar
Is this still "a thing", aka the HDHomerun people don't/won't code a 64 bit SageTV version?
So we have to install 32 bit Sage alongside the 64 bit Sage server install, and THEN install HDHomerun? After the tuner is installed, channels scanned, and entered into Sage, can we uninstall the 32 bit Sage?
Old 10-04-2021, 01:16 PM
Tiki's Avatar
Yes and no. It is still a thing that SiliconDust still only displays SageTV as an option if it detects that you have Sage installed and their detection method looks for a certain registry key that only gets set when you install 32-bit Sage.
Installing 32-bit Sage is one possible work-around. However, apparently there are a few other programs out there that interface with the hdhr the same way as Sage, and you can just select one of them in the silicondust setup software instead. I think someone said JRiver Media software was one of the other available choices that also worked.
Source:
Old 10-04-2021, 03:03 PM
tvmaster2's Avatar
Tried three others, and none worked. Gave up and installed 32 bit, and all’s well.
regarding other things that have to be done to get up this install up and running….
I read a post of yours regarding running Service Mode in 64 bit W10, and USB-UIRT not working properly, regarding sending and receiving?
I’m not quite sure I understand - but I’ve got service mode running in 64-bit, and I CAN change channels with my USB-UIRT.
Can you explain what you meant exactly. I got a bit crossed up trying to understand what you meant by sending/receiving.
This is the thread link: https://forums.sagetv.com/forums/showthread.php?t=65932
I am using a Hauppauge 45 button remote to change channels on a satellite and cable box, via a Colossus and HDPVR. I always have Service Mode running…or at least have in the past.
Old 10-04-2021, 05:28 PM
Tiki's Avatar
The USBUIRT performs 2 distinct functions. It can act as an infrared transmitter (IR Blaster) or it can act as an infrared receiver. The transmitter mode is used to allow Sage to change channels on a STB (set top box). The receiver mode is used to allow you to use a remote control to navigate the SageTV menus when the Sage UI is running on a PC.
It appears that the current 64-bit USBUIRT driver does not allow you to use both of these modes at the same time when you run 64-bit Sage in Service mode. The reason ( I think) is that when Sage is in Service mode, the UI/Client runs as a separate process from the Server/back-end. But the 64-bit driver does not allow 2 different processes to access it at the same time.
Source:
Old 10-04-2021, 06:25 PM
tvmaster2's Avatar
Hmmm. Maybe I’m still not with it - I’m using my Hauppauge 45 button to navigate within SageTV’s server software on my W10 64 bit install. Does this count as a ‘remote control’?
Now, I also installed the Hauppauge IR apps first, and that’s the remote I selected during Sage installation. I set my sat receiver to be controlled by Hauppauge’s blaster, and my cable box to be controlled by USB-UIRT.
Old 10-05-2021, 03:10 PM
Tiki's Avatar
It sounds to me like you are not using the USBUIRT as an IR receiver. You are only using it as a blaster. You just said you are using the Hauppauge IR receiver to handle your remote control. That’s a whole separate device, so there should be no issue with that.
Source:
Old 10-05-2021, 06:10 PM
tvmaster2's Avatar
OK, so the way you referred to it was using a different, universal remote?
Old 10-05-2021, 06:27 PM
KryptoNyte's Avatar
To elaborate on this, you can install and older version SageTV 32 bit before you install SageTV 64 bit, and never use the 32 bit install.
Old 10-05-2021, 07:28 PM
tvmaster2's Avatar
Well, at least they're in seperate directories, and I've got loads of boot drive space, so if it doesn't cause any problems, I'll just leave it there for the time being. I tell you, setting up HDHomerun has been the single biggest clusterf@#$ of this new build. Everything else, save for a couple of missing plugins, seems to have gone very well.
Old 10-06-2021, 05:06 PM
KryptoNyte's Avatar
I'm sorry I didn't think of that pulldown menu for SageTV in the HDHR software, I forgot about that. I am glad you got it running, and I hope you are able to use the 64 bit version. My server has been far more stable since moving to 64 bit. I do connect 4 or 5 extenders of various types, so that may add to my positive experience with 64 bit and memory usage over time.
It's unfortunate that the HDhomerun crew has basically abandoned SageTV since the Google takeover. I understand why, but it sure would be nice to get them on board a bit.
Old 10-06-2021, 05:49 PM
Tiki's Avatar
I don’t know if anyone from the Sage community even tried reaching out to SiliconDust to request they change their logic. It seems like it would be trivial for them to fix this.
Source:
Old 10-06-2021, 06:17 PM
KryptoNyte's Avatar
I reached out to them a year or three ago about Sage. They didn't seem interested. I just went to find the post I made on their own forum, but 3rd party software information seems to be truncated to 2021. Not sure where to find older posts.
Old 10-06-2021, 08:49 PM
wnjj wnjj is offline
Maybe I'll see if I can come up with a program or extra installer (or part of the 64-bit one) that creates just enough 32-bit stuff to allow HDHR to see SageTV. That would be much lighter weight than an entire SageTV 32-bit install/uninstall.
Reading a bit more back in time, the reason this wasn't done previously was that it could mess up intentional 32-bit installs that people want to keep. I'm not sure there is a good answer.
Windows Installer
Old 10-06-2021, 10:11 PM
tvmaster2's Avatar
It’s likely with a dwindling user base, most companies don’t even know what SageTV is. I heard (or read) a Channels DVR review the other day, and it was if the reviewer thought this was the first time a software DVR existed.
Sigh…
Old 10-07-2021, 12:09 AM
jchiso jchiso is offline
How can you tell if you're running 64-bit Sage?
I have a 64-bit Win 7 system that works with HDHomerun tuners. The HDHomerun Setup is Version 20210301, BDA Compatibility Mode is set to SageTV.
I don't know if the SageTV channel scan works, but the HDHomerun setup finds all of my tuners and allows actual playback within Sage.
I believe this system has 64-bit Sage on it, but I don't know how to confirm; either the System Information screen nor the .properties file readily denotes the architecture ...
Old 10-07-2021, 01:16 AM
If the install path was default, 64-bit will be in “Program Files” without the “x86”. If you run SageTVServiceConrol.exe on 64-bit, the window title will have 64 at the end.
You can also check the running application in task manager: https://www.tenforums.com/tutorials/...dows-10-a.html
Windows Installer
Configuration complète. biozzz SageTV France 11 03-12-2011 08:19 PM
Complete Command Set? KoolKat_Milw SageTV Beta Test Software 11 07-01-2007 07:41 PM
Recordings in V4 not complete dvd_maniac SageTV Software 2 11-11-2005 07:55 PM
Complete Removal ket SageTV Beta Test Software 2 04-19-2004 04:53 PM
