Old 02-23-2014, 09:46 PM
samgreco samgreco is offline
MediaTitles.xml Help
I know this has been asked before, but I am not quite getting this right. I have this in my MediaTitles.XML file:
<titles>
  <match>
    <regex>[\\/]Doctor Who.*</regex>
    <title>Doctor Who</title>
    <year>1963</year>
    <metadata type="TV" name="tvdb">76107</metadata>
  </match>
  <match>
    <regex>[\\/]Doctor Who Confidential.*</regex>
	<title>Doctor Who Confidential</title>
    <metadata type="TV" name="tvdb">79298</metadata>
  </match>
  <match>
    <regex>[\\/]Doctor Who (2005).*</regex>
	<title>Doctor Who (2005)</title>
    <metadata type="TV" name="tvdb">78804</metadata>
  </match>
</titles>
But all of these episodes end up being seen as the original 1963 series. I have the files named like:
Doctor Who - S01E01 - An Unearthly Child.mkv
Doctor Who (2005) - S01E01 - Rose.mkv
Doctor Who Confidential - S01E01 - Some Name.mkv
There are also Specials which I have named as above, but using S00Exx.
Anyone see what I'm missing here?
Old 02-24-2014, 10:04 AM
graywolf's Avatar
graywolf graywolf is offline
Wonder if the order matters?
put the following AFTER the others? Or possibly remove it?
Wouldn't Doctor Who.* match Doctor Who (2005) and Doctor Who Confidential ?
  <match>
    <year>1963</year>
  </match>
Another possibility IF you have them in different folders, ie for folder Doctor Who (2005)
  <match>
    <regex>[\\/]Doctor Who (2005)[\\/]</regex>
  </match>
Old 02-24-2014, 10:12 AM
I hadn't thought of reordering them. But the folder idea may be the best way to do this, since I do have them separated in their own folders. I'll see what happens.
Old 02-24-2014, 08:40 PM
Argh. So I changed it to:
<titles>
    <match>
    <regex>[\\/]Doctor Who (2005)</regex>
    <year>2005</year>
  </match>
    <match>
    <regex>[\\/]Doctor Who Confidential[\\/]</regex>
  </match>
  <match>
    <regex>[\\/]Doctor Who[\\/]</regex>
    <year>1963</year>
  </match>
</titles>
I also tried to ad th .* and then this l[\\/] to the Doctor Who (2005) section. The others are working correctly now, but all of the 2005 imports are being seen as movies now. They used to work.
I won't even start on Specials....
Old 02-25-2014, 06:45 AM
<titles>
    <match>
    <year>2005</year>
  </match>
    <match>
  </match>
  <match>
    <year>1963</year>
  </match>
</titles>
The easiest way to set this up, is to do the following...
1. delete your current dr who entries in the mediafiles xml.
2. restart sagetv (to ensure that all entries are unloaded)
3. go into bmt, browse and find a dr who episode... click find metadata, select the "right" dr who entry for the show you have loaded.
4. click Add Matcher
5. Use a "Folder" based matcher, click OK (or done, not sure which).
6. Save.
7. Repeat for a different episode of DR Who for different dr who show.
Keep in mind you are doing this 3 times... once for each type of dr who espisode.
Next, rescan your dr who files -- with force update/overwrite.
I never manually modify the mediatitles xml (except to clean it out), I just use BMT's "Add Matcher".
That's good.. .because there's no support for them.
Old 02-25-2014, 06:54 AM
graywolf's Avatar
Can you try this
  <match>
  </match>
Leave off the YEAR tag. Maybe the YEAR tag might be throwing BMT off to think it is a Movie and not a show?
Maybe even leave off the <title> ?
I haven't bothered with the YEAR tag for my shows that have different years.
For Example, my Hawaii Five-O work well with this configuration
  <match>
    <regex>[\\/]Hawaii Five-0 (2010)[\\/]</regex>
    <metadata type="TV" name="tvdb">164541</metadata>
  </match>
  <match>
    <regex>[\\/]Hawaii Five-0 (1968)[\\/]</regex>
    <metadata type="TV" name="tvdb">71223</metadata>
  </match>
Old 02-25-2014, 07:15 AM
Hawaii five-o is a bit different one has an alpha O and the other has a numeric 0 in the TVDB. Sage groups them all together ...
Hawaii Five-O
Hawaii Five-0
Old 02-25-2014, 08:21 AM
Thanks stuckless.
Old 02-25-2014, 08:57 AM
Hmmm. Where do I find?:
Old 02-25-2014, 12:10 PM
I was paraphrasing the actions
Browser -> Sage Video Imports by Folder -> (the navigate to the dr who folder to scan)
Click "UPdate Metadata..."
Check first 3 options, uncheck last two...
Click Scan
Repeat for the other 2 dr who folders
Old 02-25-2014, 12:16 PM
OK. That's what I thought. Just wanted to be sure.
Didn't work. What's so confusing is that it used to work for both DW and DW 2005. Even after I restored the original MediaTitles.XML file, it never worked again.
How can I completely remove any metadata info from those files and start over?
Old 02-25-2014, 12:25 PM
Could you email me your complete mediatitles.xml file? (metadatatools at gmail dot com)
Old 02-25-2014, 12:43 PM
Actually, this is all there is.
<titles>
    <match>
    <year>2005</year>
  </match>
    <match>
  </match>
  <match>
    <year>1963</year>
  </match>
</titles>
Old 02-25-2014, 03:14 PM
<titles>
    <match>
    <year>2005</year>
  </match>
    <match>
  </match>
  <match>
    <year>1963</year>
  </match>
</titles>
So, is it failing for all 3 shows... ie, which of the 3 matchers is it using when you scan, now?
Old 02-25-2014, 03:40 PM
Sorry for the confusion Sean. It's only failing currently on Doctor Who (2005).
Old 02-26-2014, 06:07 AM
JerryB JerryB is offline
Just a thought but do you mean to have 2 spaces between "Who" and "(2005)" and does your actual title match this?
Old 02-26-2014, 08:34 AM
JerryB - Funny I saw that thinking it was 2 spaces. It's not. I have triple checked it because it still looks like too much space.
Old 05-08-2014, 06:16 AM
silkshadow's Avatar
silkshadow silkshadow is offline
Necro thread but you need to escape your "(" and ")". Here is my Dr Who:
  <match>
    <regex>[\\/]Doctor Who \(2005\)[\\/]</regex>
  </match>
Old 05-08-2014, 11:33 AM
  <match>
  </match>
Thanks for this! That seems to have fixed it for me.
I had gotten busy and not returned to this problem until I got the notification of a response to remind me.
Old 05-08-2014, 12:19 PM
graywolf's Avatar
  <match>
  </match>
Interesting. I will need to try this out.
BTW, what other characters should be escaped?
MediaTitles not Working wmstonetn Batch Metadata Tools 9 07-08-2015 02:15 AM
Help with MediaTitles.xml Phydeaux Batch Metadata Tools 3 12-04-2012 01:47 PM
Help with mediatitles.xml, please? silkshadow Batch Metadata Tools 5 10-22-2012 08:26 AM
MediaTitles.xml and how to read it razrsharpe Batch Metadata Tools 28 01-22-2011 07:57 AM
Problem with MediaTitles.xml cmaloney Batch Metadata Tools 12 08-17-2010 07:44 PM
