whs or unraid?
I'm planning on going to a 2 hdpvr system (at some point), and I was trying to figure out if it's better to go w/ 1 server running whs or 2 boxes--one with the server and one running unraid.
From a cost point of view, I'm leaning towards the 2 boxes UnRaid since I can build it from 'cheap' parts and still use my current server (a p4 3ghz) to record from the hdpvr. Will it work streamign to extenders & clients and stuff? thanks, rwc |
Go with the 2 boxes. I've been going that route for a while now with no regrets. I keep all music and DVD rips on the unRaid, and run Sage on the WHS box with the recording drive out of the pool. Best of both worlds, and anything recorded on WHS that is deemed worthy of archiving, get's copied over to the unRaid.
-PGPfan
Sage Server: Gigabyte 690AMD m-ATX, Athlon II X4 620 Propus, 3.0 GB ram, (1) VistaView dual analog PCI-e tuner, (2) Avermedia Purity 3D MCE 250's, (1) HD-Homerun, 1.5 TB of hard drives in a Windows Home Server drive pool, Western Digital 300GB 'scratch' disk outside the pool, Gigabit LAN Sage Clients: MSI DIVA m-ATX, 5.1 channel 100w/channel amplifier card, 2 GB ram, , (1) Hauppauge MVP, (1) SageTV HD-100 Media Storage: unRAID 3.6TB server |
I'm currently testing unraid with SageTV. I chose unraid based on easy expansion (mix different size HDs in the future), and low overheard for redundancy (single parity drive) -- something whs, and other NAS solutions didn't seem to offer.
So far, it has been working well, but I only have 2 clients connected to it. I'd be interested in hearing what issues other may have had with Unraid and SageTV. |
Unraid is rock solid once you get it up and running. The only thing I would like to see is the ability to use it as a drive to record to for hd recordings with sagetv. Drive space would no longer be an issue.
Server: Asus M3A; AMD Phenom quad core CPU; 3Gb RAM ; ATi x1600 PCIe Video Card Tuners: 1 Adaptec PVR 3610, 2 PVR 500s; 1 HDHomerun; 2 HD PVR Storage: 1.2 Tb Clients: 2 HD Extenders |
I use a UNC path for recording HD programs. Why would using an Unraid NAS box be any different than using a different windows machine for storage of sagetv shows? I have never used unraid, but it says it does windows networking on its webpage so it should be viewed as a windows UNC path like anything else.
The difference has to do with the write speeds for the unRaid. Writes are slower due to the need for calculating and writing to the parity drive in addition to the files destination drive. Read speeds has never been a problem.
This has supposedly been rectified by the inclusion of a 'cache' drive in unRaid, but I've never tried using the cache drive as the Sage recording drive so I have no idea if it'd work in the real world. -PGPfan
I assume that the UnRAID server appears as a mapped drive to your SageTV computer.
Why can't you use the UnRAID drive for recording HD content with the mapped drive? Is the throughput too low to keep up with the recording process? Is mapped drive playback of HD content stored on the UnRAID server OK? It looks like the UnRAID operating system can only be installed on a USB jump drive, instead of conventional hard drive or solid state drive. Do you know what happens if the USB jump drive fails? Can the USB jump drive be replaced with a backup USB jump drive, then boot up again without any data loss? Or are all your files stored on the UnRAID hard drives gone after the USB jump drive failure? Dave
SageTV: LIAN LI PC-K58, Gigabyte GA-EX580UD5, i-7 950 3.06 gig quad LGA 1366 CPU, Zalman CNPS9700 CPU cooler 1366 bracket, Memory 24 gigs GB, PNY NVIDIA GeoForce 9800 GT 1024 MB, Corsair 750w PSU, Samsung 840 Pro 128GB SSD boot, 3 x 1.5 TB Capture cards: 2 - HDHR Primes - Comcast Xfinity CableTV Extenders: 1-HD-300, 2-HD-200 Software: Windows 7 Pro X64, Ghost 15, VideoReDo TVSuite 4 h.264, Playon (Netflix), OpenDCT UnRAID File Server 4.7 Pro: Lian-Li PC-G70B, MBD-X8SIL-F-O, i3-540, 16 TB |
Later, like 3:00 in the morning, or whenever you assign it to, unRaid will then move the data off of the cache disk - calculating parity at this time - and will write the data to it's final destination. All this, keeping the directory structures fully intact so Sage has no trouble dealing with unRaid. It's quite an impressive system, really. As for recording HD content directly to an unRaid drive, I can't comment there as I'm not recording HD yet. Quote:
-PGPfan
Also, there is a tweak to increase read performance on unraid 4.3.3 by ~ 30%. I haven't tested if it increases write performance. I'm currently using a HVR 2250 (2 QAM tuners) and I don't seem to have a problem writing HD recordings to Unraid, without a cache drive. Add to that a shameless plug for my email notification script, that can send an email to my phone if any of the drives in the unraid server starts acting up or overheats, and I'm pretty happy with it. Last edited by brainbone; 11-28-2008 at 07:06 AM. |
Personally I'd spend the $30 for NASLite2 and not have to worry about any of these difficulties. It's fast (no problem streaming 2 HD streams to it at once), cheap and very reliable.
www.serverlements.com
Sage Server: ASUS/Intel C2D based system w/4GB RAM. Win7, Hauppauge PVR 150, Hauppauge HVR-2250 and an HDHR. Runs headless. Accessed via VNC when necessary. Four HD-300 Extenders. |
My understanding is that you need a hardware raid controller to get any type of redundancy from NASlite2, otherwise, it's JBOD.
I use two boxes as well. All my music, picture and movies are on UnRaid and the TV recordings are on the Sage server.
You could use user shares and the cache drive feature to use UnRaid as a recording disk, I don't because I don't want parity protection on TV recordings. If I want to keep a TV show I archive it, then move it to UnRaid, otherwise I keep it on the sage server. Discussion of why someone would choose UnRaid over any other NAS solution can be a lenghty discussion. . . |
Also true. All of them have their pros and cons and we all will have different results. I read how many people loved FreeNAS but when I tried that it was an unmitigated disaster. It was completely unreliable and never stayed up more then 30 minutes without crashing.
Settles it for me, Ive been considering Netgear's X-RAID, a Drobo (way to expensive), FreeNAS, and a traditional RAID-5 for a while, but none of them were exactly what I wanted.
Heard of UnRAID today, and im sold. Gonna grab the plus version. Thanks for the info! ![]() |
I have never used Unraid but have been a satisfied user of WHS for about 18 months now with no regrets.
I am only using it for SD recording, but have never had difficulty with the drive management program in WHS, it easily has allowed me to replace and upgrade different sized drives without issues. I recently update to a newer "faster" server and was able to upgrade without having to restore data from a backup "which I made just in case" it kept all of the data intact and imported it cleanly back into the system "see we got served forums for details" I like to keep network bandwidth as clean as possible, and not having to stream video across a 100Mb connection to record it onto remote storage is a plus. This way I can serve more extender units with multiple streams and not saturate my connection. Plus I am cheap and 1 server will take less space, generate less heat, and consume less electrical power, all pluses ![]() Just my 2cents
SageTV HD100 Extender SageTV MVP Extender Media Server-WHS - 2GB Ram - 3TB storage - Windows 7 MC - My Movies Plugin for Win7MC "Life is a banquet and most people are starving to death!" |
I have unRAID for my storage but do not write directly to it.
I use SJQ to move the recordings to the unRAID server after they are recorded. Have not had any problems viewing from unRAID server other than maybe an initial pause if the drive that the recording is on is spun down. Once spun up, no issues at all. Been very happy with unRAID. |
Out of curiosity, how does spinning down the drives compare to the power savings of putting the machine in standby?
I would guess it's close, but I don't know |
Thanks for posting. I have been pondering doing a NASLite server, and now I can add unraid to it. I guess the question is do I want to have a "backup" of what I put onto that machine (and I use the word backup lightly by the way). I have no problem with the cost, but I think I am still leaning towards NASLite.
Media Server: Win 7 Home (32 bit), GIGABYTE GA-EP43-UD3L LGA 775 Intel P43 ATX Intel Motherboard, Intel Core 2 Quad Q9505 Yorkfield 2.83GHz, 4 GB Ram, Geforce 9600 GT PCI-E, 1x HD PVR, HD homerun (2x for OTA, 1x for FIOS QAM), 1 x HD Homerun Prime with cablecard from FIOS. Client: Windows 10 Pro Media Extenders: HD-200 x 3, HD-200 x 2 |
Sage recording on WHS crashes server | vhurst | SageTV Software | 5 | 11-26-2008 12:00 PM |
Deleted SageTV save directory keeps reappearing in WHS | Nerva | SageTV Software | 2 | 11-14-2008 12:35 PM |
Sage for WHS license question, and other blather... | vhurst | SageTV Software | 16 | 11-11-2008 07:32 PM |
SageTV & WHS - storage only or recording too? | jeroen020 | SageTV Software | 1 | 09-11-2008 09:19 AM |
Linux or WHS? | tmiranda | SageTV Linux | 8 | 08-12-2008 05:43 PM |
