Old 11-26-2016, 06:36 PM
RBraverman's Avatar
RBraverman RBraverman is offline
V9.0.9 and Windows Not Sleeping with Service
Anyone other than me having problem with their systems not sleeping with the service running in V9.0.9?
Running powercfg -requests shows the SageTV Service running, while V9.0.4 does not. In 9.0.9 if I stop the service it goes to sleep.
******************* Update *******************
Now upp'd to V9.11 and it goes to sleep - until you do a conversion. At that point NOTHING will get it to sleep again, restarting service, restarting computer, etc.
Core2Duo 3.0, 8gig Memory, Win7 x86, LOTS O' Storage tucked into an Antec Case. OLD aTI Remote Wonder.
Sage V9.0.13.536
Java V1.8.0_121 (8.11)
Base STV V7.1.9.12
JettyWebServer V2.3.0.14
Phoenix Core V 3.0.4
Old 11-29-2016, 05:44 AM
Can you test something for me? When your server is in that "won't sleep after a conversion" state, check the list of conversions (Videos -> Video Conversions). It is probably showing the completed conversions in there. From there, you can remove the completed jobs, so the list is empty, and see if the server will then go to sleep.
I think this is an issue from a change I did a few months back to prevent the server from sleeping when there are transcode jobs in progress, but I may not be ignoring already completed jobs.
Old 11-29-2016, 12:54 PM
RBraverman's Avatar
THANKS for reply.
I have been leaving them there ...
In the middle of "playing" - my wife would re-phrase it - comskip to create the proper vpj file for VRD V5.
But I'd LOVE to get this fixed. Then I'd only have ONE problem and ya' all could get rid of me ....
************************UPDATE**********************
I just KNEW you could figure this out, A GRAND DAY OUT! and a beer to ya!
FWIW I'm using V9.111 or is it 9.0.111, or 9.1.0111
Sage V9.0.13.536
Base STV V7.1.9.12
Old 11-29-2016, 05:53 PM
okay, if that confirms the problem, it should be an easy fix when I'm back near my dev machine. So after that's fixed, and a new build comes out, failed and completed jobs in the queue will not keep it awake, only running and waiting jobs will.
Old 11-29-2016, 07:55 PM
RBraverman's Avatar
Smile
Cool, take your time. At least I know what it is that was/is keeping the service going. And thats why even a reboot or service restart wouldn't clear it.
Any ideas of having time contraints for conversions? Say only run from 12:00am to 6:00am?
Anyway, MANY thanks.
Sage V9.0.13.536
Base STV V7.1.9.12
Old 11-30-2016, 02:33 AM
I'm sure it's been discussed before. Can't really see much real world point though, as really the only times a conversion are going to be added are right after a favorite is recorded (for an auto-convert), or manually requested - both of which the system is already awake, and may be better to just get it over with then, while the system is also likely to be up for other reasons (further prime-time recordings, or viewing) than some off-hours time where it'd only be awake for the conversion.
Old 12-01-2016, 02:17 PM
RBraverman's Avatar
Ya kinda have to remember that a lot of the boxes used - the ones that aren't nix boxes - are win7 with older H/W.
In the middle of converting a 1:45hr movie and I'm into my 4th hour, now if there were recordings scheduled IN between that ... this poor ol' Core2Duo would be a' strugglin'.
Sage V9.0.13.536
Base STV V7.1.9.12
Running SageTV at Windows startup (as a service) orrd SageTV Software 11 02-06-2016 06:55 PM
Windows installer and running as a service Opus4 SageTV Github Development 13 01-01-2016 07:33 AM
XP to Windows 7: SageTV service does not autostart owilsky SageTV Software 6 04-14-2010 03:50 AM
SageTV 5.04 Service Goes to 100% after Windows Updates KB935839 and KB935840 djssage SageTV Software 0 07-25-2007 10:50 PM
SageTV Service crashes after Windows XP autoupdate techtips SageTV Software 42 01-12-2006 04:37 PM
