Old 01-06-2017, 03:58 PM
mtncrux mtncrux is offline
Which plugin for fanart in the default interface?
How do I get fanart and descriptions for my ripped DVD's in the default STV interface? Which plugins do I need to install?
I just rebuilt my SageTV PC with Windows 10 and also upgrade from SageTV v7 to v9. I saved my wiz.bin file, but I wasn't smart enough to note which plugins I had installed, or save any of the art files. I hadn't touched my configuration for 4+ years so I have no idea what I did last time to get it working.
Are there any other "must have" (or really useful) plugins that you recommend for the default interface? Right now the only plugin I have installed is the commercial skip plugin.
Thanks to everyone who has kept SageTV going. I've been using it as my only media center since v5 and it is nice to see that it is still alive and well.
Old 01-06-2017, 09:20 PM
I think it's under UI Mod > Phoenix Fanart for SageTV.
Plugins are free to try . But if you're looking for slicker UIs, you may want to try something like Phoenix or Gemstone. I personally just use the stock with the fanart plugin.
Add Fanart Banners to Default Stv bigo93bronco Batch Metadata Tools 3 01-24-2011 03:10 PM
Default Fanart when nothing found? wayner Batch Metadata Tools 2 12-30-2010 07:35 PM
Default poster when there is no fanart Oats SageMC Custom Interface 0 10-21-2010 04:53 PM
STV Import: Phoenix Fanart for the Default STV tmiranda SageTV Customizations 83 04-25-2010 04:39 AM
How to get the default STV interface? BigBirdy SageMC Custom Interface 3 01-18-2010 11:25 AM
