Old 01-27-2017, 06:01 PM
sflamm sflamm is offline
custom views with SageMC
Questions:
1. I had customized SageMC to have a couple views for my home videos and photos.
Will I be able to use those views directly with Phoenix 3.0?
2. a. Does Phoenix 3.0 require BMT?
b. does BMT work under SageTV 9 running Java 8
* Moved out of unrelated topic *
Old 01-27-2017, 08:01 PM
jusjoken jusjoken is offline
Originally Posted by sflamm View Post
Questions:
This should be in the Phoenix 3 forum but 2 a and b are yes.
For 1 i am not sure if sagemc used phoenix views.
k
Old 01-27-2017, 10:56 PM
No, SageMC does not use phoenix views (I think it actually predates most the work in Phoenix).
Old 05-13-2017, 03:13 PM
Correct. It has its own "PathFilterExpr"... which provides a similar (but less powerful) ability.
And SageMC will read the central Fan Art folder (generated by Phoenix Core).
My mistake was juxtaposing Phoenix Core and Phoenix 3 (STV)
Custom views with filters? medwynd Sage My Movies 4 05-11-2011 02:07 PM
Can you have Custom TV views wayner Diamond 2 04-10-2011 09:29 PM
Custom views and SMMFolders chrishallowell Sage My Movies 3 01-28-2011 05:41 AM
Custom Views wiki and questions thread!! PLUCKYHD Sage My Movies 11 01-19-2011 06:55 AM
Custom OSD for SageMC bialio SageMC Custom Interface 1 05-02-2008 06:20 AM
