Old 02-05-2017, 01:51 PM
michaeldjcox michaeldjcox is offline
Problem downloading plugins on V7.1.9
Reposting this here - as I misposted in the open source area...
I tried to reinstall sagetv V7.1.9 today.
All fine until I tried to install plugins e.g. web interface.
Various jars would not download from sourceforge for example:
ERROR with file download of:javax.net.ssl.SSLHandshakeException: Received fatal alert: handshake_failure
Sun 2/5 12:36:28.495 [PooledThread@6a460f] Resource download failed from http://sourceforge.net/projects/sagetv-addons/files/3rd_party_libs/json-20140107.zip/download
I got this with java v6, v7, v8 using the latest of all those.
Downloading from that link in a browser works fine
It was suggested V9 would solve this problem but I could not get that to start the server - so cannot prove that.
I also tried downloading a plugin on my untampered with test system and its the same there.
Anyone know whats going on here?
Is it a problem with sourceforge?
Web Feed Encoder developer
SageTV Catchup developer
Old 02-05-2017, 02:18 PM
Managed to get V9 working on my test box.
It does indeed seem to fix the issue with sourceforge downloads.
Is 7.1.9 then effectively dead if we can no longer install plugins?
Old 02-05-2017, 02:37 PM
There seem to be problems with the plugins on sourceforge. Given the ticking clock on V7 due to the EPG here in NA it doesn't appear that anyone is working on fixing it.
Old 02-05-2017, 03:58 PM
EnterNoEscape's Avatar
I wouldn't call it dead, but definitely less active/supported. Also a lot of the new downloads are https which doesn't work with v7 at all.
SageTV v9 Server: ASRock Z97 Extreme4, Intel i7-4790K @ 4.4Ghz, 32GB RAM, 8x 3TB 7200rpm HD, 2x 5TB 7200rpm HD, 4x 256GB SSD, 4x 500GB SSD, unRAID Pro 6.3.0-rc6 (Dual Parity + SSD Cache).
Old 02-05-2017, 04:27 PM
jusjoken jusjoken is offline
The active developers here have been able to correct many of the plugins by updating the new V9 plugin Repo which unfortunately does not fix it for V7 users....but as V9 has been around for some time now and the EPG is just months from being history on V7....we all need to focus on getting users to V9 rather than fixing V7 issues.
Glad to see you have worked out the V9 issue.
k
Old 02-05-2017, 11:05 PM
tvmaster2's Avatar
tvmaster2 tvmaster2 is online now
I've finally succumbed and installed v.9 on a test run. So far, every plugin I tried was installed. This was driving me nuts as well with v.7
Friends fresh install of V7 onto WHS 2011 and plugins problem waynedunham SageTV v7 Customizations 9 09-07-2016 09:59 PM
Which plugins should we include as core plugins, if we were to auto-install plugins? stuckless SageTV Github Development 35 07-08-2016 04:01 PM
Re-downloading software NCC SageTV Software 7 11-19-2010 11:02 PM
How do plugins get into the list of plugins? michaeldjcox SageTV v7 Customizations 4 06-12-2010 03:05 AM
Downloading Version 5.x withak SageTV Software 0 12-23-2007 01:57 PM
