Old 09-30-2007, 05:57 PM
nightlyraver nightlyraver is offline
Remote Stopped Working!
The title says it all. The remote itself does work - when I start WinTV it works fine. However, it all of a sudden does not function in Sage at all.
I recently removed and reinstalled my WinTV and all Hauppauge drivers and utils. Was this the cause? Do I now have to reinstall Sage? If so, how can I preserve all of my setting, customizations, etc.
-Dan
____________________________
HTPC Black Aluminum Case, Athlon X2 6000+ 3Ghz processor, ASUS M2R32-MVP580X CrossFire AM2, 2gigs DDR2 800 dual-channel ram, MSI RX2600XT Diamond Plus 512MB GDDR4, 1 500gig SATA drive, 1 330 gig SATA drive, Happauge HVR-1600 tuner card, ATI Wonder tuner card (hey, I had it in the closet), SageTV ver.6.2 w/ SageMC.
Old 09-30-2007, 08:44 PM
Yes -- you need to have irremote.ini (in your Windows directory) modified so that it will work with SageTV. This is done by the SageTV installer, or you can use a backup copy or one you download. See this FAQ or my sig lines: post 3 in link 1 or post 15 in link 3.
Old 09-30-2007, 09:56 PM
Thanks a bunch...worked!
-Dan
Remote not completely working one4u2nv Hardware Support 15 01-17-2007 11:19 AM
Remote stopped working with 6.14 wado1971 SageTV Beta Test Software 2 11-25-2006 09:13 AM
Firefly remote and Sagetv 5....Not working right??? rdefino Hardware Support 4 09-20-2006 04:23 PM
License stopped working sleonard SageTV Placeshifter 2 07-27-2006 10:11 AM
Other input for hauppauge remote? orangezero Hardware Support 2 04-25-2006 11:17 AM
