Old 10-19-2010, 07:52 PM
KipKasper's Avatar
KipKasper KipKasper is offline
Question USB Audio
Does anyone run an external (USB) sound card for SPDIF out on a client?
I'm setting up a new client PC that is a very small form-factor, with only stereo audio. I have in the past run an MVP with Coaxial Digital audio and was very happy with that setup, so I would like to recreate it on my new client.
I was looking at something like this startech
http://ncix.com/products/index.php?s...tech.com%20Ltd
But i thought i would check in first, are there are problems with USB audio or SPDIF i should know about?
- Kip
Server:P4 3.2Ghz, Win XP Pro, 2xPVR-500 V7.0.20.243 Java 1.6.0_22
Client:Optiplex sx280 Win7 Pro 32bit
MVP
Old 10-19-2010, 10:03 PM
I use a Turtle Beach Audio Advantage Micro in my living room - Mainly because the PC itself is 30 feet away in a closet. Has worked great for years. If all you're going to use it for is a single SPDIF output, I see no reason for anything more than that.
Old 10-20-2010, 09:37 AM
KipKasper's Avatar
Thanks Fuzzy,
Looks like the Micro has been updated to the Micro 2, and it should do the job just fine. Thanks for saving me a few bucks
- Kip
MVP
client, spdif, usb audio
New cable box and now audio is out of sync. Audio Delay in Detailed settings working judoGTI SageTV Software 0 05-29-2010 12:09 PM
USB PCI Card & Hauppauge USB ATSC Tuner Sticks and/or HD-PVR - Do They Work? Savage1701 Hardware Support 5 07-07-2009 08:42 PM
USB Tuners fail when add USB drive taylormadearmy Hardware Support 4 11-08-2008 06:18 PM
RC3 no audio from firewire STB, audio fine on PVR-500 rob.sfo SageTV Beta Test Software 1 10-26-2005 10:53 PM
mpeg audio error with usb headphones jmeeks SageTV Beta Test Software 7 04-16-2003 10:24 AM
