Old 11-09-2007, 09:28 PM
1234567 1234567 is offline
is there a tuner priority
Hi folks,
I am new to sage tv, but I gotta say that I like it a lot.
I currently have three tuners and I am waiting for one more to go on sale. Anyway, I have two internal FusionHDTV tuners and one USB Pinnacle tuner. Not all tuners are created equally, for example, FusionHDTV tuners change channels much faster than the Pinnacle, and they also have much much better analog tuning. On the otherside of the coin, the Pinnacle is noticably more sensitive and can pick up channels the others only catch in good weather, which is why I ask about tuner priority. I would like to get schedule information from the online guide service, and have only the Pinnacle tuner get certain channels, so I don't end up recording a blank. Is there a good way to do this?
Old 11-09-2007, 09:53 PM
ke6guj ke6guj is offline
there is encoder_merit that is set in sage.properties that will allow you to set your preference in the order that you would prefer Sage to use the tuners. It is not absolute, only a preference. If you open up sage.properties, with Sage completely shut down, you will see encoder_merit=0 in the config section for each tuner. If you change the 0 to a higher number, it will prefer the tuners in order from highest to lowest.
If you have access to a second EPG source, a neighboring city perhaps, you could have one source for the Fusions with the "blank" channels disabled and another source for the Pinnacle with all the channels.
- Jack
Tuner issue after HDHR install jcato Hardware Support 3 10-17-2007 10:29 AM
Feature request: Manual set which tuner to use for recordings bbig119 SageTV Software 4 04-29-2007 08:15 AM
Setting tuner preference (merit?) Fallen Kell SageTV Software 2 01-11-2007 11:04 AM
Tuner priority settings problem naln SageTV Software 0 12-13-2005 01:51 PM
BDA Tuner Test Application Stealth1971 Hardware Support 17 04-19-2005 10:50 AM
